If it had a 7.3, it should bolt right in minus a few simple things. There was a guy that dropped an IDI in his 99 V10 after it blew a few plugs. Not active on here anymore tho
pre 97 is non smogable.
I don't see the IDI mounts bolting into this frame, but I could be wrong.
SD engine mounts wont bolt up to an IDI.
when I get there, ill mount the trans on the trans mount and figure out some sort of plate mount system.
Y'know... If the Roadkill guys can fabricate a mount for just about any engine in a couple hours, it ought to be doable for anyone with a welder, cutoff wheel, and some steel...
doing mounts isn't the issue, this can easily be done. I was just looking to see what others have done before I get to them.
ive done some crazy fab projects, but ive always looked for whats out there and what other people have done before pullin the trigger.
if I can pull off a DIY RSK, engine mounts will be a sinch
