Starter/starting issues
Old Apr 10, 2010 | 01:49 PM
bigenough's Avatar
bigenough
Well when I turn the ignition to start it only clicks, i had the starter tested several times at three different places passed everytime its only 3 months old. I have checked all the fuses and relays all good im lost at this point any advise would be greatly apprecaited! Thanks!
Old Apr 10, 2010 | 02:00 PM
crazymut's Avatar
crazymut
Only clicking sounds like a dead battery. In our case two dead.
Old Apr 10, 2010 | 03:31 PM
bluescrew's Avatar
bluescrew
battery OR battery cables! ( i have lot of experience with this)
Old Apr 10, 2010 | 03:40 PM
bigenough's Avatar
bigenough
Both batteries where fully charged several times that I tried, I thought maybe the cables where bad but just a thought!
Old Apr 10, 2010 | 04:00 PM
bluescrew's Avatar
bluescrew
doesnt matter if batteries were charged... i charged mine with my battery charger till the lil green light went on..... but i took em in to get tested and they were BOTH bad..... my batteries were about 5 months old and BOTH were bad... its free to get them tested. its a good place to start...
Old Apr 10, 2010 | 05:39 PM
Quick444's Avatar
Quick444
I have two new batteries, a new relay and a new starter and I still have clicking issues. I won't work them out till this summer though when its warm outside.
Old Apr 10, 2010 | 07:06 PM
fifthwheel01's Avatar
fifthwheel01
Same here had to take them to two different AZ'z for a second opinion. They would NOT hold enough power to hold a second load.
Old Apr 10, 2010 | 07:30 PM
bigenough's Avatar
bigenough
I have tested both batteries, more than once. I took jumper cables crawled underneath and the starter spun but didnt engage.
Old Apr 10, 2010 | 08:25 PM
PaysonPSD's Avatar
PaysonPSD
Relay #307 is designated Start Relay.
Do you get a single click each time you turn the key to start or is it a continous click with key in start position?
Is the clicking coming from under the dash?
If you don't have an owner's manual the attched is a PDF of fuse and relay info for a 2002. Should be the same for a 2003.
Owner's manual download available HERE.
Old Apr 10, 2010 | 08:36 PM
Quick444's Avatar
Quick444
I get a single click over and over with the occasional start. This is the only thing I haven't tried yet. Sometime it even dies right in the middle of turning over. Sorry to high jack the thread.
Old Apr 10, 2010 | 09:27 PM
bigenough's Avatar
bigenough
its a single click at the starter, i ohmed out all the relays!
Old Apr 16, 2010 | 06:39 PM
Quick444's Avatar
Quick444
Ever figure anything out? I am going to go and try the fuse today or tomorrow.
Old Apr 16, 2010 | 07:02 PM
Quick444's Avatar
Quick444
Am I correct to assume that on a 2001 I would be replacing the # 20? Labelled Starter Motor Relay Coil
Old Apr 16, 2010 | 07:19 PM
Quick444's Avatar
Quick444
Never mind! That is just a 20 fuse under the dash. I checked the power box under the hood and found two 50 maxis labelled as ignition switches. Neither of them seem blown.
Today I took my cables off and wire brushed them and the terminals on the batteries. I all ground down the cable enough so that they would firmly tighten around the terminals. Still clicking!
Old Apr 19, 2010 | 07:36 AM
bigenough's Avatar
bigenough
No! I havent figured anything out. I'm gonna take off the entire cable and inspect it from top to bottom.
