Troubleshooting Glow Plug Relay Circuit?
Old Nov 20, 2016 | 05:08 PM
Kingkong0192's Avatar
Kingkong0192
Ok, for a friends truck. It's a 1996 F350 7.3.
He has a hard time starting it in the morning when it's cold.
I grabbed a test light and checked the glow plug relay for him.
From what i've been reading, one big post is power from battery, one small post gets power when the key turns on, the other big posts sends power to the glowplugs, and the other small post is controlled by the ECM to ground/power the post.
As for the one that's controlled by the ECM, his always has power. It never gets grounded, so the glowplugs never come on.
I've read that the ECM looks at data from the air temperature sensor, and the oil temperature sensor to determine when to ground the relay to power the glowplugs.
I'm thinking that one of these two sensors is bad, or there's a short in one of the wires, and the ECM isn't getting any data from it therefore not turning on the glowplugs.
Or am i totally heading down the wrong path?
Thanks.
Old Nov 20, 2016 | 05:45 PM
nateairman's Avatar
nateairman
Best to use a volt meter and measure voltage drop. Measure voltage at big post key on the most you want to see as a difference is .3V
Old Nov 20, 2016 | 07:28 PM
Kingkong0192
im sorry. Maybe I wasn't clear enough. There isn't any voltage going to the glow plugs because the ecm isn't grounding the relay.
I know the glow plugs are functioning because if you jump battery voltage across the relay and to the glowplug stud and hold it there for ten seconds the truck will instantly fire up.
Old Nov 21, 2016 | 08:34 AM
knottyrope's Avatar
knottyrope
sounds like an open to PCM or the PCM, you need to ohm out the wire to the PCM
Old Nov 21, 2016 | 01:19 PM
Kingkong0192
ill check it when I see my buddy. I think he's out plowing with it.
I figured if it was open then there wouldnt be anything at the relay coming from it.
Old Nov 22, 2016 | 04:04 PM
tjc transport's Avatar
tjc transport
i ain't rite
correct.
if you want to get him going until you find the problem, you can bypass the pcm with a momentary contact push button switch connected to the ground side of the relay, then run the wire into the cab to the push button switch. the other side of the switch to ground. tell him to key on, hold the button down for 15 seconds, then start the truck.
if really cold he may have to up the time to 20 seconds.
Lockholder
16
Dec 10, 2018 08:52 PM
Jo7.3
25
Jan 12, 2018 09:40 PM
jtak101
17
Jan 19, 2017 11:50 PM
fordff
Mar 25, 2005 08:34 AM
quiethorse
Dec 7, 2004 11:00 PM
