1997 7.3 Injectors Sound Choppy on Decel
what fuel pressure do you have at idle and WOT? it has a bit of injector knock and starving for fuel can make injectors louder
Also with that many miles you might want to check armature clearance
http://dieselpro.ca/Poppet%20Valve.pdf
FWIW My truck does the same exact thing on decel. There has never been any hesitation or poor engine performance otherwise.. it's done it since I bought the truck.
I also notice my truck will ever so slightly change idle speed; but It's not enough for me to throw a million parts at it. Fact is the truck has 286k and runs great otherwise.
If I were to look at anything I would think my IPR needs to be rebuilt; however thats not going to happen until I absolutely have to.
I pretty much am in the same boat as Frank, my truck has 98k on it, Cali emissions, it has a little variation in idle and does a funky little decel thing. I have new injector O-rings and the truck starts, runs, excellerates, and goes fantastic otherwise..
Oh and I listened to your video, had to hold the phone up to my ear because theres a lot of background noise where I am right now and I didnt hear anything out of the ordinary...?
I will say that I do get a more pronounced choppy idle after i throw a CEL for the hpop after "lettin-her-have-it" in my highest tune, the truck will continue to run choppy until I shut it off then start it up again. When I agreed with Frank above that would be with the truck in the "stock" setting..
aocabrown
02-15-2009 01:49 PM
