Sponsored by: Auxito
5.4L and 5300 Vortex
Old Aug 24, 2003 | 10:04 PM
dilas's Avatar
dilas
I just had an opportunity to drive a base Suburban model with 5300 vortex recently. To my surprise, it performed stronger than my 5.4L F150. My 98 5.4L is approaching 60K miles, and it's time for the major service soon. The major service would include things such as all fluids changed on transmission, gears/axles, filters, and etc. The spark plugs is scheduled for 100,000 miles. Assuming the 5.4L is as powerful as the GM's 5300, what attention should I look for to restore the power back in 5.4L during the service? Should I go ahead and have spark plugs replaced at 60,000 instead of 100,000 to improve the performance? I tow a 3000 lb camper regularly during weekends, and I noticed sluggish power driving up slopes.
Old Aug 25, 2003 | 12:07 AM
Lectrocuted's Avatar
Lectrocuted
Blasphemy!!!! Don't you know Ford is the best. Just kidding. I'm in the same boat as you are. I'd go ahead and get the plugs changed before they decide to exit themselves (see sparkplog blowout posts). Don't forget the fuel filter.
Old Aug 25, 2003 | 06:07 AM
aldridgec's Avatar
aldridgec
You won't get your 5.4 "back" to the 5.3 Vortec. The vortec has 285 hp while your 5.4 has 230 hp.
Its debateable if the 5.3's power is useable, as its a running motor that will scream to the redline. Whereas the 5.4 has more torque down low.
Good luck on your maintenece items
Old Aug 25, 2003 | 11:54 AM
kspilkinton's Avatar
kspilkinton
Not to mention the gearing may have been in the Suburban's favor. Deeper gearing makes vehicles feel more responsive with more seat of the pants feel.
Try to clean out the air intake and throttle body.
-Kerry
Old Aug 26, 2003 | 10:58 AM
B_7700_4X4's Avatar
B_7700_4X4
I thought that the 5.4L had 260HP?
Old Aug 26, 2003 | 11:28 AM
peterbilt's Avatar
peterbilt
B_7700_4X4
The 99s and newer have 260 hp and 350 ft-pds torque. 25 more ft-pds of torque, but 25 less hp than the chevy 5.3.
Pete
Old Aug 26, 2003 | 08:08 PM
aldridgec's Avatar
aldridgec
Not in 1998.
Old Aug 26, 2003 | 10:35 PM
dilas's Avatar
dilas
Thanks guys for replies. I'm just hoping that after doing the service, it'll be running better and bit stronger. If not close to the 5300 Vortec, at least I won't be second guessing the 5.4L. Will keep you posted on results after doing this service shortly.
David LaPell
13
Jan 11, 2014 09:36 PM
David LaPell
1997 - 2003 F150
Jan 6, 2014 02:32 PM
Super Duty Mike
Mar 23, 2012 07:35 PM
Fredster
1997 - 2003 F150
Feb 20, 2007 09:59 PM
TexFord
Nov 30, 2002 08:51 PM
