1978 - 1996 Big Bronco
Tire clearance issues
Old Sep 5, 2003 | 04:31 PM
  #31
broncowife's Avatar
broncowife
OK, I have a 1990 bronco XLT and by what I'm getting here is that I can go with 33X10.5 R15 on my stock rims and without a lift kit?? I have to be thankful enough for my bronco my hubby sure wouldnt let me get a lift put on it too...he already calls me a redneck HA
Old Sep 5, 2003 | 04:54 PM
  #32
treehugger36's Avatar
treehugger36
actually BroncoWife you can stick 33x12.50s on it if you like. You will just have to shim out your front bumper a bit for clearance issues...
that is the conclusion I have come to
  #33
btnbronc's Avatar
btnbronc
i had a 89 bronc and i put 33x10.5 on it without a problem but the rims were not stock they were a little deeper
Old Sep 5, 2003 | 04:55 PM
  #34
btnbronc's Avatar
btnbronc
oh yeh i hated the way it looked the tires were too thin
Old Sep 5, 2003 | 04:57 PM
  #35
broncowife's Avatar
broncowife
whew thanks guys...i dont like all that empty space between the tires and the fender wells
Old Sep 7, 2003 | 07:53 PM
  #36
justshootme84's Avatar
justshootme84
In regards to the front lift/leveling coils, I was going to go that route as well before I found out this potential problem: If you have the offset, factory camber bushings (above the upper balljoint), you may have a hard time getting the front end alignment right. Be sure to check this out and see if the new alignment bushings will work for you. I also had problems with alignment on a 6"lift kit with stock radius arms and dropdown brackets. There was no way to get enough caster in the front end, and the right coil spring was actually rubbing one of the shocks. The extended arms helped relieve this problem.
Old Sep 7, 2003 | 10:25 PM
  #37
fatfenders's Avatar
fatfenders
Shootme84
I ordered the Rancho leveling coils. I am aware of the potential alignment problems. My tires are cambered in just a bit at the top now. The taller springs should bring it closer to correct. If not, oh well, it only takes an hour to remove them and I can always dump them on ebay. This is more than likely temporary anyway. I know a 4 inch is in the not so distant future. I won;t be content after I see a few more of you guys do a real lift.
But I just got the truck so I need to spend some time undercoating the undercarriage and fixing some minor body rust before it gets worth. After figuring out how much it costs to do a lift, front locker or LS, wheels and tires etc. It just doesn't make any sense to not get the bodywork done first before it's not so minor. They really throw the salt around in the winter up here.
lp92chateau
Jun 12, 2021 12:11 PM
1998E250conversion
22
May 7, 2016 05:34 AM
Ron94150
Dec 19, 2015 12:32 PM
NjOffRoaderX
1997 - 2003 F150
Apr 10, 2011 03:07 PM
92Custom
21
Jul 14, 2002 02:57 PM
