Headlight switch & pigtail connector...
Hey all, I'm going to replace my headlight switch as well as the wiring harness that connects to it on my 84 f150. Correct me if I'm wrong, but it should be a 7 prong connector right? I called Lordco and they told me they have the headlight switch part # s-453, which has (according to them) 8 prongs, and the wiring harness that they have only has 3 prongs? If someone could provide me with pictures and part numbers for these 2 parts that would be great.
thanks
Jared
thanks
Jared
If you want to look at the oem connectors, there is a link in the stickies to the Motorcraft pigtail identification guide.
this shows all the oem harness wiring connectors grouped by how many contacts there are in the connector.
When you have the Ford part number *and the Motorcraft service part number* it is pretty easy to shop around for best pricing.
Question, are you swapping the switch and harness because of previous heat issues that warped or damaged it?
If so my biggest suggestion after replacing those is doing headlight relays (if you havent planned that already)
What a huge difference it makes, did it on a few fords, it helps remove all the heavy current draw thru the switch, and IMO helps with light output.
Caveman Eric
12-18-2017 03:07 PM
Bwetzel
11-20-2012 12:40 PM
