1978 - 1996 Big Bronco
Headlight Switch...Again
Old Jun 23, 2004 | 03:47 PM
BroncJMU's Avatar
BroncJMU
Ive got the **** off, and i bought the new headlight switch. How do i get the old one out? Do i really have to hook my hand around blindly back there underneith and pull it out?
Or does more of the dash come off so i can get at it from the front?
Thanks.
Old Jun 23, 2004 | 04:59 PM
marv0's Avatar
marv0
What year is your Bronco?
I replaced the headlight switch on my '79 without any problems.
Old Jun 23, 2004 | 07:15 PM
BroncJMU's Avatar
BroncJMU
86 headlight switch
I got the "bolt" out that holds the switch to the back, but i still cant get my hand back there to seperate the switch from the wiring harness. What else can i disconnect to loosen the whole harness.
Old Jun 23, 2004 | 07:42 PM
94F150-408's Avatar
94F150-408
If you have replaced your switch more than once, you might want to cnsider doing the wiring that you can find in the tech articles titled brighter brights and whiter whites. This will take the current load off the headlight switch and you'll have alot brighter headlights. I did it on my truck, check it out in my gallery under lighting upgrades.
