6.2L V8 Discuss the 6.2L V8
need help
Old Nov 15, 2016 | 11:43 AM
johnno5's Avatar
johnno5
need help
I posted this up in the super duty forum also. does anyone know how to disconnect the coil from the wire harness on the 6.2l coil on plug???
Old Nov 15, 2016 | 11:43 PM
Tarster's Avatar
Tarster
there should be a little clip right on the top of the coil pack that you push the tab and pull off, thats the way it is on all my other coil over plug rigs...unless your talking about pulling the coil pack off the plug, in which case most have a 7mm bolt that you take off, pull the electrical clip on the top and then just pull the whole sucker straight out of the hole.
Old Nov 16, 2016 | 03:51 AM
johnno5's Avatar
johnno5
i see the little red tab on the top of the wire harness plug. are you saying just push it in while pulling on the plug? or do i pull the tab back first to unlock it?
Old Nov 16, 2016 | 06:17 AM
Chuck's First Ford's Avatar
Chuck's First Ford
slide the Red tab out about 1/4 inch.. press down on locking tab (not red) and remove connector from coil.
sometimes the red tab breaks.. no big deal.. its a lock for the locking tab. so a double lock.
Old Nov 16, 2016 | 06:48 AM
johnno5's Avatar
johnno5
Thanks Chuck! that is exactly the info i needed. i have already broken one red tab. i didn't know it was a double lock. Thanks again
#1fordguy
Jul 20, 2018 06:35 PM
mammothstroke
Sep 11, 2012 06:44 PM
mkoempel
Nov 6, 2011 06:56 PM
kalawikimaui
Jun 26, 2008 04:35 AM
commandersander
1997 - 2003 F150
Feb 26, 2004 02:41 PM
