E4OD woes
Old Nov 15, 2016 | 09:31 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by kgmkgm
Any particular reason why?
Because the clutch won't engage when warm and the fluid is dark and burnt. That means a clutch has failed. New fluid can't fix broken parts.
Old Nov 16, 2016 | 11:01 AM
vettex2's Avatar
vettex2
I've said that for years but hardly anybody will ever believe me.
Some DIYer will always say "change the fluid".
Soon after they then will claim changing the fluid ruined the transmission.
I'm no trans expert but it is SO refreshing to see an actual trans expert say this !!!
Old Nov 16, 2016 | 12:22 PM
Mark Kovalsky
Many people ignore the trans until something goes wrong. Then they change the fluid, and the trans fails. It doesn't matter to them that the only reason they changed the fluid is that something was wrong. The trans had already failed before the new fluid, but the new fluid wasn't able to repair what broke from their neglect.
Old Nov 16, 2016 | 03:03 PM
jeffreyclay's Avatar
jeffreyclay
Hmm, I once bought these little metal pills to drop in my spark plug holes and it would rebuild my engine. Does Ford or JC Whitney have something like that for a transmission? If the pills aren't available I would buy a new modulator and run the little screw in all the way. You need more line pressure.
Old Nov 16, 2016 | 07:40 PM
vettex2's Avatar
vettex2
kinda like the little blue pills?
Old Nov 17, 2016 | 09:33 AM
kgmkgm's Avatar
kgmkgm
No I know that. I'm not a dumdum... I am asking why its pretty well seen that the XJ AW4 trans can be revived decently enough with a fluid flush if its slipping a little bit, and sometimes a solenoid replacement. Why doesn't that work with the ford trannys?
My lady's VW trans blew up at 95,000 miles and come to find out the valve body is made of swiss cheese so it wallows out, and the hard parts shatter. It literally isn't rebuildable without so much work that will only get it another 50K that it isn't worth it financially. I'm wondering why the E4 is the way it is? Just the way it is? The vans are much heavier than my XJ, so I was wondering if its because once its F-d, the vans are too heavy to ever get the clutches to not slip. The XJ trannys are probably slipping but its light enough to still go forward? You seem to be knowledgeable and I got nothing but learning to do.
Old Nov 17, 2016 | 09:38 AM
Mark Kovalsky
I've had experience with transmissions from several manufacturers. I have NEVER seen one that slips and can be repaired by changing fluid. Once they are slipping it means a clutch is damaged. New fluid can't repair any brand of clutch.
I suspect that the Jeep trans wasn't really slipping, but had some bad shifts. New fluid CAN often fix this, even in Ford transmissions.
Old Nov 17, 2016 | 09:42 AM
kgmkgm's Avatar
kgmkgm
Bad shifts meaning like it doesn't build line pressure or something like that? I have a basic understanding of auto trans but not too deep. No job means I have time to read, ha.
Old Nov 17, 2016 | 09:07 PM
Mark Kovalsky
The transmission always had line pressure. It can build and fall in less than a second. That's not the problem. Bad shifts can happen from old, worn out ATF. The frictional properties of the fluid change as it wears, and this will affect the shifts.
Old Nov 17, 2016 | 10:26 PM
mbolton1990's Avatar
mbolton1990
So ATF should never be changed? Lol, just trying to figure out your logic.
Old Nov 18, 2016 | 06:48 AM
Mark Kovalsky
ATF should be changed. My point is don't wait until the trans has a problem before changing the ATF. Change it per the factory maintenance schedule.
Old Nov 18, 2016 | 08:57 AM
kgmkgm's Avatar
kgmkgm
My motorcycles don't shift well when their trans oil gets dirty, so I guess that makes sense. Old fluid just making the gears not mesh well, vs the clutch packs not engaging properly I suppose?
Old Nov 18, 2016 | 09:22 AM
  #28
Mark Kovalsky
Old oil in a manual trans will affect the synchronizers, not the gears. Gears will mesh with or without new fluid.
Old Nov 18, 2016 | 09:33 AM
  #29
kgmkgm's Avatar
kgmkgm
I don't think the motorcycle trans have synchros in them.
Old Nov 18, 2016 | 10:24 AM
  #30
Mark Kovalsky
I was guessing. I don't know motorcycle transmissions. I do know that gears will mesh with new oil, old oil, and for at least a little while, they will mesh with no oil.
