1967 Ford F600 VIN decoding
Old Nov 15, 2016 | 01:08 PM
JEFFFAFA's Avatar
JEFFFAFA
On the rear brakes I need to know if this truck has Bendix or Kelsey Hayes style 15" X 4" brakes. Note, on Bendix type the upper and lower wheel cylinders are different. On the Kelsey Hayes style all 4 cylinders are the same,.
Old Nov 15, 2016 | 04:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by JEFFFAFA
Bitte.
Ford part numbers for the front brakes so far. (I'm at work now) Some of these 1967 F600 brake parts were 1967 and older. In 1968 they changed.
B7T2069A....brake shoe hold down pin.
B7A2066A....hold down spring cup.
TDAA2068A..hold down spring.
B7Q2035A (all 4) upper shoe return springs.
TDAA2049A...lower shoe return springs.
TDAA2047A & TDAA2041A & TDAA2048A are the 3 part numbers that made up the self adjusters.
C4TZ2061B...R/F wheel cylinder.
C4TZ2062B...L/F wheel cylinder.
C3TZ2007D...brake shoe lining kit.
C3TZ2007DMR...remanufactured brake shoe lining kit.
Upper Pic shows the basic part numbers for the complete part numbers El Jeffe gave you above.
1964/72 Ford Truck Parts Catalog available on a C/D from hipoparts.com
Old Nov 16, 2016 | 11:58 PM
Gunter Ettel's Avatar
Gunter Ettel
Bitte.
On the master cylinder I show 2 choices.
1967 F500/600...with 11.50" booster..booster Midland Ross #C-4063...M/C I.D. 1 1/32"...part number C6TZ2140B.
OR
1963/70 F500/850 (with single hyd. vac. brakes)...with 12.75" booster...booster Bendix #2503258...M/C I.D. 1 1 1/2"...part number C3TZ2140L.
Hello Jeff,
thank you so very much for your research and so much helpful information.
I am in contact now with Hagen's Auto Parts and they said they can supply all brake parts and also front end parts. I will forward your information to them for them to make their research a bit easier.
I want to thank you for all your help Sir.
Greetings
Gunter
Germany
Old Nov 17, 2016 | 01:06 AM
Gunter Ettel
thank you Matt
Originally Posted by matthewq4b
No Problem Gunter if you end up stuck let me know and I can pick the stuff up from NAPA and ship it to you. I get a 35-50% discount off list on most items with our NAPA account and with the Canuck dollar in the toilet the exchange is pretty favorable for you €1.00 Euro = $1.45 CAD.
Hello Matt,
I do not know how to thank you for your friendly offer to help me to get these parts for me. It is very rare that people go out of their way to do something good for others without receiving anything in return. But all that counts is
to feel pleasure to help someone in need and to simply receive a smile and a "thank you" back in return. I am actually the same way.
I am in contact with Hagen's Auto Parts and a very friendly guy behind the counter names Brandon said he can help me to get all the brake and front end parts together. I want to wait and see with what all he can come up with and hopefully he can supply everything I need. I have emailed him all the information I could gather here on this forum to ease his research.
If I do get stuck somewhere, I sure will keep you in mind and come back to you to ask you to get me something.
Thank you a thousand times Matt. Meanwhile...should I not talk to you again, I wish you a wonderful Thanksgiving.
Greetings
Gunter
Germany
Old Nov 17, 2016 | 09:25 AM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by Gunter Ettel
Hello Jeff,
Greetings
Gunter
Germany
Bitte.
Note. Hagen's Auto Parts is also going to have to know if the truck has Kelsey Hayes or Bendix style rear brakes. As of 1966 F600's got either/or. If they guess you may get all the wrong parts.
JakeK
Mar 4, 2018 05:59 PM
66duke
Mar 28, 2016 03:52 PM
Lyle Vass
Jun 13, 2014 06:24 AM
