Another ball joint thread
Old Nov 15, 2016 | 02:17 PM
BillyBob69's Avatar
BillyBob69
Luckily I don't have to deal with ABS on the front. E99 built 10/98
I do plan on replacing the bearings but I also plan on going easy with it.
I am taking time off work since I have a lot of vacation time to burn so I will have about 7 days to get this done.
Old Nov 15, 2016 | 02:57 PM
BillyBob69's Avatar
BillyBob69
Ya gotta love it when your wife goes...well if you need it and will use it again later, then you should go get it.
WOOT! New 20 ton shop press in the SUV now. hehe
May be Harbor Freight but considering I don't do any of this for a living and it will prolly be used 4 or 5 times a year... Ill take it! Now to find a new home for it in the shop.
Old Nov 16, 2016 | 10:12 AM
DND58's Avatar
DND58
Bill, seen this one before?
Lots of parts and pics!
Ford Super Duty Ball Joint Replacement Procedure - Superdutypsd.com
Old Nov 16, 2016 | 10:29 AM
BillyBob69's Avatar
BillyBob69
Holy crap! Ok That has got to be the best write up I have every seen.
parts listings... pics...descriptions. Looks like it probably took more time for the write up than it did for the job! Thank you for the link! Wouldn't of bothered posting if I had found that. Time to save it!
And it looks like I did get the right parts too. That's always a plus!
Now to run to the hardware store to get the pieces for the knuckle seal tool.
Old Dec 5, 2016 | 10:33 AM
BillyBob69's Avatar
BillyBob69
The saga continues...
OK...new ball joints, outer tie rods, brakes all around, new tires... she drives straight. no longer fighting alot of play in the wheel...but...
when going through a slight dip at an angle so the tires hit 1 at a time, I get a popping sound and slightly feel it. like when going from the road into a parking lot..the dip there. to me it sounds like it is centered, but to the passenger, they feel it on their side so I would say passenger side.
so...what next should I check?
Old Dec 5, 2016 | 12:30 PM
ranagent's Avatar
ranagent
torsion bar end links
body mounts
inner hub bearings
Old Dec 5, 2016 | 12:38 PM
BillyBob69's Avatar
BillyBob69
body mounts
inner hub bearings
Ummm no torsion bar... Solid front axle.
body mounts - will have to check those.
inner hub bearings - all new. rebuilt the hubs while I had it apart for the ball joints.
I was going to look at the sway bar end links and bracket mount bushings. Aren't these known to pop when worn? Don't remember if these are a common cause.
Old Dec 5, 2016 | 12:48 PM
ranagent's Avatar
ranagent
Yeah I meant sway bar when I said torsion bar, yeah they can pop and can go out frequently
Old Dec 5, 2016 | 12:51 PM
BillyBob69's Avatar
BillyBob69
AHHHH OK That makes sense. You said torsion and my first thought was my ZR2 Blazer. Already did those too!
Thanks!
Old Dec 5, 2016 | 01:06 PM
Walleye Hunter's Avatar
Walleye Hunter
I had a front end klunk that went away when I changed my sway bar end links but I was not able to see that they were the problem, I just got lucky.
Old Dec 5, 2016 | 01:51 PM
brian42's Avatar
brian42
Veteran: Navy
x2 for sway bar end links. It's free to check. Remove the sway bar, put it in the garage, and go for a drive. You'll know pretty quick if it's the end links or not.
Old Dec 6, 2016 | 07:39 AM
ExPACamper's Avatar
ExPACamper
Anybody have a favorite sway bar end link writeup link?
Old Dec 6, 2016 | 08:15 AM
  #28
BillyBob69's Avatar
BillyBob69
Check out post #5 Great info!
https://www.ford-trucks.com/forums/1...end-links.html
Old Dec 6, 2016 | 08:58 AM
  #29
BillyBob69's Avatar
BillyBob69
So speaking of bushings...this means that the kit I need will be the 4.5192... right?
I have the E99, build date 10/98.
brandon.edwards
Jul 27, 2012 10:13 AM
KennyG228
Nov 27, 2010 09:46 PM
sumbuddyloanmea.10
May 26, 2009 11:57 AM
mongo75
Mar 16, 2007 01:07 PM
77hiboyboy
Feb 24, 2006 06:41 PM
