Sponsored by: Real Truck
Disabling Engine Start Up
Old Nov 14, 2016 | 03:49 PM
MisterCMK's Avatar
MisterCMK
Thwap the inertia switch and fuel pump won't come on.
Old Nov 14, 2016 | 05:43 PM
Misky6.0's Avatar
Misky6.0
I would NOT do that. Depending on engine (gas), it might still start and get going then run out of gas (diesel prob won't start). That would be bad even for a sober person.
Get the club, it keeps the wheel from turning and will likely discourage driving. It also deters theft!
Win-win.
Old Nov 15, 2016 | 11:01 AM
redford's Avatar
redford
FTE Leadership Emeritus
But, to add to what has been already suggested......
Please please get yourself some counseling. Join your local Al-Anon group, or get some other support. I cannot stress this enough. Help yourself first, then help your Dad.
Old Nov 15, 2016 | 12:31 PM
Jaime74656's Avatar
Jaime74656
Originally Posted by seville009
I think most trucks have a fuel shut off switch (can't think if the proper name) that triggers if you're in an accident, for example. Usually in the front passenger wheel well. You would push the button or something to reset it. Not sure if you can manually trigger it on though. Should be in your manual (or just take a look)
the fuel shut off being referred to here is an inertia switch requiring about (approximate) .5 g's to trigger, bumping with a light tap from a hammer should be enough to trigger it, your hand should do but a hammer is able to make it happen faster even the rubber Handel should suffice, as an added bonus you can always remove the relay for the fuel pump or if (if a diesel)
for more info please provide the type of truck
Old Nov 15, 2016 | 01:04 PM
Wingit929's Avatar
Wingit929
Originally Posted by redford
Get an inexpensive battery disconnect like this at your local parts store.
Yes, you'll reset everything, but if you take the **** part with you the battery will be fully disconnected and the truck will not start.
This would work but he would see it if mechanically inclined.
Old Nov 15, 2016 | 02:42 PM
MisterCMK's Avatar
MisterCMK
Win-win.
Meh, it will get the job done. No fuel means it isn't going to start.
Old Nov 15, 2016 | 07:11 PM
stufarmer's Avatar
stufarmer
isn't there an Engine ?? fuse you can pull to disable the power to the starter ?
Old Nov 16, 2016 | 12:49 PM
Trophy_23's Avatar
Trophy_23
I remember when I was on a roadtrip and had an ignition issue where I could not remove my key, so I popped by the local ford dealer and the mechanic showed me on the pass side just above the wheel well, there is a plug you can disconnect and it wouldn't start, and it would take someone a long time to find it if they went looking. In my situation it worked perfect because I had a club also, but wanted the extra protection leaving it in a hotel parking lot for a few days.
Old Dec 8, 2016 | 03:13 PM
20BHPat1600RPM's Avatar
20BHPat1600RPM
I bought a LMU-200 GPS unit with remote starter block (from GPS & Track, but believe also available from CAL-AMP). The unit is designed for those no-credit self-financing car dealers. It allows them to determine where a vehicle is, determine if it leaves a geographic area, and then prevent starting if the driver has not made their payment. It allows you to log on via the internet, including from your smart phone, and turn starter block on or off remotely. So you can disable the vehicle without stepping outside and then turn it back on once they sober up.
Old Dec 10, 2016 | 03:57 AM
GregsSD's Avatar
GregsSD
Originally Posted by asdrew
PS: On my 2000 Diesel, I also cut a switch into the Brake-Shift Interlock at the brake pedal switch so I could leave it running but not shift into gear (like when you have to step on the brake first).
Don't rely too much on the Brake-Shift Interlock method!
All someone has to do is shut the engine off, shift it into neutral, then restart the truck and take off!!!
jleal_21
21
Jul 17, 2009 11:35 AM
Dubzilla
1978 - 1996 Big Bronco
Apr 1, 2007 02:24 PM
steiny519
Jun 4, 2006 11:59 AM
Coasty
Nov 11, 2002 09:45 PM
