6.0 starting issues
Old Nov 13, 2016 | 07:45 AM
Fldiesel73's Avatar
Fldiesel73
6.0 starting issues
2006 6.0 won't turn over. Recent work has been #4 and #8 injector, oil cooler, egr delete. Ficm is showing 47, pulled the icp and truck still won't start. Getting fuel to the filter and oil to the filter. It did crank up and run for awhile yesterday and ran absolutely perfect. When I cycle the key you can hear the injectors buzzing and the fuel pump. There are three egr codes that I'm only assuming are on due to the egr delete and one for the glow plug control mod to pcm. I live in fl and the temp is 70 degrees. Please tell me your thoughts on this. I'm also reading oil pressure on the gauge so I'm assuming the lpop is good. Any help is greatly appreciated!!
Old Nov 13, 2016 | 11:19 AM
Fldiesel73's Avatar
Fldiesel73
Any help guys, I need to get this heifer back running for work tomorrow.
Old Nov 13, 2016 | 02:41 PM
navistarnut's Avatar
navistarnut
Won't turn over or won't start? First post is a bit confusing
Old Nov 13, 2016 | 03:16 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Yeah, what he said...
How many PSI are you building while cranking?
Old Nov 13, 2016 | 03:24 PM
Fldiesel73's Avatar
Fldiesel73
Will turn over but no start. Don't know psi.
Old Nov 13, 2016 | 03:55 PM
BLADE35's Avatar
BLADE35
You need to know HPOP psi
Kinda sounds electrical since it intermittened
Old Nov 13, 2016 | 04:20 PM
BLADE35's Avatar
BLADE35
you can take a chance and pull the IPR see if the screen blown out and stuff a screwdriver in it
you just did an oil cooler so that's common to trash an IPR soon after
Old Nov 13, 2016 | 04:21 PM
BLADE35's Avatar
BLADE35
it would be better to just have one thread to so everyone can see what been done and also suggested
check all plugs an Oil cooler is Pretty well a gut out of the electronics
Maybe an IPR wire was pulled/stretched IDK
Good Luck!!
Old Nov 13, 2016 | 05:40 PM
Fldiesel73's Avatar
Fldiesel73
Thanks for the replies and sorry for the sporadic questions. Having it towed into a shop in the morning for diagnosis.
Burt Watkins
Oct 15, 2018 12:13 PM
Fldiesel73
Nov 7, 2016 08:41 PM
slammed03
Oct 13, 2011 12:18 PM
plowin4u
Mar 17, 2011 08:30 PM
grudgeracer
Sep 2, 2009 07:01 PM
