Wiper wiring help
Old Nov 12, 2016 | 07:13 AM
49f3dls's Avatar
49f3dls
Wiper wiring help
Purchased a NOS 6 volt positive ground wiper motor and have no idea where each wire will go. Black, green and red. I will need to get a switch but any help will be appreciated. No instructions came with it and I do not know if it is single speed, dual speed or variable speed.
Old Nov 12, 2016 | 10:03 AM
ALBUQ F-1's Avatar
ALBUQ F-1
What is the model number? Should be something like WWFxxxxx
Old Nov 12, 2016 | 02:53 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
This is how my stock 52 is wired thanks to members of this forum. Looks different but, maybe it will help. Two speed in my case.
Old Nov 12, 2016 | 03:07 PM
49f3dls's Avatar
49f3dls
ROSS The model is WWC 6K 517 -- Said it fit a whole bunch of 6v positive ground cars/trucks.
Thanks Scott
I hooked up a wire from the motor housing to frame (positive)
I could not find a switch so using a headlight switch to test.
black wire goes to tail light side
red wire goes to parking light
green goes to headlight
then battery connection goes to NEG side of battery
Turn switch on to parking and motor runs fine
pull switch to headlight and nothing happens - does not run
So my question is what does green wire do??
I tried switching red and green and still nothing on green??
I guess I can always just run as one speed which is fine and better than vacuum wipers but want to be sure I am not going to burn something up. I do have a 10 amp fuse on every line so I think I may be safe.
Thanks for helping.
Old Nov 12, 2016 | 03:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I found this on the net, on a Jeep site. It explains the functions of each connection. You need a matching switch.
Old Nov 12, 2016 | 03:28 PM
49f3dls's Avatar
49f3dls
Ross -- I am a total electrical dummy (and on many other subjects also) and do not understand what the diagram is telling me. I am still trying to find the correct switch - just wanted to be sure the motor worked and I could still use it if I can not find a switch.
Old Nov 12, 2016 | 03:33 PM
Scotty's 52 F3
I don't remember what wires did what. It's been a while. Ross or somebody posted up how it was wired as it is not on a schematic. I hooked it up as instructed and it worked.
Old Nov 12, 2016 | 04:39 PM
49f3dls's Avatar
49f3dls
Just found a switch that is suppose to fit this motor so ordered it. Hopefully that will solve the green wire question. I think it is the wire that tells it the "PARK" position as shown in your diagram Ross - at least that is what I think you are trying to tell me Thanks guys I appreciate the help
Old Nov 12, 2016 | 05:48 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The resistor makes me think the motor is 2 speed, is the switch? If the motor is 2-sp, my diagram is not applicable directly
To be honest, the wiring on the motor looks hokey to me. Let me think on it...
Old Nov 12, 2016 | 06:02 PM
49f3dls's Avatar
49f3dls
Yes the switch is 2 speed. Says it is for a 517 so hopefully it will work
Thanks for your help.
Old Nov 12, 2016 | 06:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Did you put the red/green/black wires on?
Here is how the single speed diagram above works.
Old Nov 12, 2016 | 08:00 PM
Ibuildmyown's Avatar
Ibuildmyown
Old Nov 12, 2016 | 09:40 PM
49f3dls's Avatar
49f3dls
The headlight switch has 5 terminals. The motor has 3 wires plus a 4th I hooked up to motor housing to make it easier to hookup for test. Left side has parking and headlight terminal right side has 2 tail light terminals but they are connected together. Back side has terminal for battery and front has pull to turn on off. I put red wire to parking light terminal. Green to headlight terminal. Black to tail light. Then I put a new wire on battery terminal which I hooked to negative on battery. The wire from motor housing went to positive on battery (6 volt positive ground). Pulled switch out to parking light position (red wire) and motor ran fine. Pulled it out to be headlight position (green wire) and the motor stopped.
I switched the red and green and then the parking position did not work but the headlight position did run. So red works green does nothing. Does that mean the green is the PARK position side of the motor? Does this mean the motor only has one speed?
Have I mentioned how much I hate electrical issues on an old beast !
Thanks guys.
Old Nov 12, 2016 | 10:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Is this headlight switch a 48-52 Ford? Because the headlights and parking lights are fed separately on those switches (see below). You could just jumper the two power feeds to see if it changes things.
Old Nov 13, 2016 | 07:10 AM
49f3dls's Avatar
49f3dls
I have a 10 amp in line fuse on each wire just to be safe so I don't. Burn the motor out so I will try moving wires around and see what happens. I may just have to wait until switch arrives later this week.
Hell_Fish
May 7, 2014 01:05 PM
RicManSr
Aug 3, 2009 02:33 AM
53ford
May 8, 2009 11:05 AM
mercman86
General Automotive Discussion
Mar 8, 2009 07:57 PM
66 F-100
Dec 12, 2008 08:37 PM
