6 or 12 Volt? Vacuum or eletric?
Old Aug 1, 2009 | 12:39 PM
RicManSr's Avatar
RicManSr
I'd like to hook it to a battery to see if it works. Can anyone tell me what the Red Green, Black wires go to? I don't want to burn it up if I hook it up to a 12 volt battery & it's a 6 volt motor. My truck has a Ron Francis wiring harness & updated powertrain, so I'm not to familiar with the orginal equipment on it. Any help on the wires (red, green, black 12 volt or 6 volt) would be greatly appreciated!
Thanks
Ricky
Old Aug 1, 2009 | 02:49 PM
RicManSr's Avatar
RicManSr
OH, btw this is for the windshield wiper motor.
Old Aug 1, 2009 | 03:51 PM
RicManSr's Avatar
RicManSr
Nevermind, I found it:
Originally Posted by Julies Cool F1
Quote:
Originally Posted by 53ford
Yes, I do have the switch. I will look at it tonight. I do know from a previous glance that the switch also has a yellow wire. I assumed that was
the incoming 12v (B) to the switch. A little confused by your comment of touching two wires to make it run. I understand the fast/slow wires, but how does the parking wire function?
The motor should be grounded throught the case. One wire is low speed, one wire is high speed and one wire is for the parking position.
If you ground the case, and secure the thing in a vise - cause it's gonna jump, you should be able to touch two of the three wires with power and it should run.
Question, do you have the switch, was it hooked up and do you remember what color went where? The tabs on the switch are labeled. P= Parking; B= your power into the switch; A= normal speed; and F= Fast speed.
Ground the case with the negative post on the battery, then touch each wire individually with a lead from the positive post - when touched, on two of those three wires, the motor should run.
There have been a couple of really good threads on the "Parking" function.
Rather than re type, I'll let you read throught them.
https://www.ford-trucks.com/forums/80...er-wiring.html
https://www.ford-trucks.com/forums/84...-question.html - Post #15
Old Aug 2, 2009 | 02:21 AM
Julies Cool F1's Avatar
Julies Cool F1
Hi Ricky!
Just a follow on...Your 56 wiper motor should have been electric and was originally 12 volt. For wire colors and hookups to the switch refer to the 56 shop manual.
Good luck!!!!
Old Aug 2, 2009 | 09:15 AM
RicManSr's Avatar
RicManSr
I took the wiper motor aprt last night & the 3 wires that go into it from the switch was all melted together in a big clump of plastic. I stripped everything back down & cleaned everything up. I sanded everything down, soildered three new leads in, cleaned everthing up, put in a new daub of grease & volia`, It all works now. All I need is a few nuts & bolts, some clips & wiper arms & I'm good to go.
Thanks Julie,
Ricky
Old Aug 3, 2009 | 02:33 AM
Julies Cool F1
Don't ya just hate those big melted globs of wires - YIKES!
