High idle adjustment: screw, sensor and?
Old Nov 10, 2016 | 12:36 PM
Resendiz's Avatar
Resendiz
My idi doesn't seem to show any difference in cold and warm idling.
I tried the screw, but it doesn't change the idle. Is there something else that I need to be looking at?
Old Nov 10, 2016 | 02:14 PM
madpogue's Avatar
madpogue
Does the solenoid plunger move when you first turn the key to RUN when the engine's cold?
Are you pressing the pedal before starting the engine, to allow the solenoid plunger to move its full travel?
Old Nov 12, 2016 | 08:03 AM
tjc transport's Avatar
tjc transport
i ain't rite
there is a temp sensor in the head near the side of the thermostat housing. you can only see it by looking straight down between the rad hose and alternator. if the plug is off the sensor, you will have no timing advance or cold idle increase.
bgab3
Jan 5, 2013 01:11 AM
fordguy_460
Dec 1, 2009 07:55 AM
superduty4x4
15
Sep 17, 2008 11:32 AM
indebt
Jan 11, 2008 07:43 PM
blueovalwonder
Feb 20, 2005 10:26 PM
