Bronco II Ford Bronco II
broken front axel
Old Aug 24, 2003 | 12:16 PM
green_6's Avatar
green_6
broken front axel
the passenger side front axel in my 85 brnc2 snaped where the secondary axle meets the stub shaft.The ears on the secondary shaft where the u joint goes into broke off.Has any body else had this happen.
Old Aug 26, 2003 | 07:41 PM
beefysbronco's Avatar
beefysbronco
broken front axel
It happens. Usually because the tires are to big or you had them spinning really fast and then got traction............. Usually takes some abuse but it is an easy fix. All ya have to do is get a different one and swap it out. I am very hard on my axles and my tires are larger then stock so you really must have done something to break it. LOL
Good luck
budman23
Jul 9, 2011 08:33 AM
vonleyser
Jan 2, 2011 06:16 PM
bakerbuilttracks
Apr 23, 2009 07:18 PM
fireball318
Jun 13, 2007 09:08 PM
res_q_me2001
Apr 21, 2003 05:35 AM
