Full size door panels?
Old Nov 7, 2016 | 11:02 AM
ranger332's Avatar
ranger332
Does anyone know where I can get a full size door panel like this one for my 76 F100?
Old Nov 7, 2016 | 12:21 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Very common reproduced part. Cheap version ck out LMC, quality version ck out Dennis Carpenter, Jeff Bronco Graveyard. National Parts Depot..
BOTP 73-79 Door Panel Set - accept padded arm rests - Presidio (Gray)
The carpet on the bottom part of the door is not factory for a 73-79
Old Nov 7, 2016 | 12:22 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I would recommend Dennis Carpenter. They have panels in red, blue and black. Your gray panel has been painted/dyed that color. Gray wasn't offered as a factory color.
Their panels run around $100 each but seeing as you'll need to paint them, Dennis Carpenter sometimes has off color panels for $100 pair.
These panels don't include the carpeted section below the panel.
Old Nov 7, 2016 | 12:24 PM
CelticOne's Avatar
CelticOne
Regular User
I thought the same thing when I first saw this thread - but look at his panel. It is larger ("full size?"), up to the window and even farther up the door post. Haven't seen one like it.
Old Nov 7, 2016 | 12:30 PM
ranger332's Avatar
ranger332
Yeah this isn't the standard door panel. It's a full size that goes all the way up and up the window frame too. I really don't care about the carpet on the bottom. I just like the full panel because there are small holes in the bottom of my inner door that look like something should be there. The doors are off if a 78 F150.
Old Nov 7, 2016 | 12:32 PM
77&79F250's Avatar
77&79F250
Bruce I do not think so, I think you are confusing the grey outer paint for plastic. Look at his dash color, grey also. It looks like a standard door panel to me. With carpet added where the map pockets sometimes go.
I can see the red in between the bottom of the door panel and the top of the carpet...on the left side of it.
ranger give us another pic of all the door.
Old Nov 7, 2016 | 12:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I was thinking the door had been painted to match the panel.
If the OP posts the "body" code from the door warranty plate , I'll see if there's anything different.
Also, check the "DSO" code (last code on the plate), is it two digits or six?
Old Nov 7, 2016 | 12:42 PM
ranger332's Avatar
ranger332
This is a vehicle for sale. I saw the listing and liked the door panels. I have no idea if their original ir not, although I would guess not. This is a pic of the doir tag on the same listing fir this truck. Uts advertised as a 78 F100 custom.
Old Nov 7, 2016 | 12:59 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The "EZ" trim code means saddle and tan all vinyl with saddle appointments (81E). The 81E is the "Ranger" trim level, nothing special or unusual there.
The two digit DSO (24) means it was ordered through the Jacksonville district sales office and was a "stock" order. If it was ordered with non-standard or special order equipment, it would have a six digit number instead of two.
Old Nov 7, 2016 | 01:37 PM
CelticOne's Avatar
CelticOne
Regular User
I see what you mean, Rich. I compared it to one of mine. Good eye.
Old Nov 7, 2016 | 01:39 PM
rougeriver's Avatar
rougeriver
I like the way that looks with the door painted grey. At first, I thought that it looked like there was additional thickness with perhaps an upholstered surround but it appears to be the transfer of the weatherstripping.
David
Old Nov 7, 2016 | 02:23 PM
ranger332's Avatar
ranger332
So that's painted? Wow! That's a great job! I thought it was rare full size door panel.
Old Nov 7, 2016 | 07:15 PM
77&79F250's Avatar
77&79F250
Door panel ideas for days.
twozzie
Jul 11, 2015 11:09 PM
Stinky7-11
Oct 30, 2011 02:54 PM
mustang4fun
Escape & Escape Hybrid
Oct 15, 2010 02:37 AM
oldjag
18
Mar 28, 2008 01:46 PM
jowilker
Mar 11, 2002 06:04 PM
