Head Bolts Vs. Studs
Old Nov 7, 2016 | 06:27 AM
Kyle Wood's Avatar
Kyle Wood
I am look at ARP bolts and studs for my cylinder heads. I know studs are theoretically better. However they are almost 100 dollars more and i am on a tight budget.
I want to do this right, however if i can get away with the bolts id rather do that. i am building a 400 and it should have around 370hp and 430trq acording to the power package i bought. with ARP bolts be fine or should i go witht he studs?
Old Nov 7, 2016 | 06:51 AM
redcreekauto's Avatar
redcreekauto
Bolts will be just fine.
Old Nov 7, 2016 | 06:55 AM
mikeo0o0o0's Avatar
mikeo0o0o0
X2, go with bolts.
Blue and White's Avatar
Blue and White
Agree bolts are just fine for your build... and much easier to service a head if needed.
Studs help, for example, on a 1,000+ hp supercharged engine but not in your case.
Old Nov 7, 2016 | 08:02 AM
somethingclever's Avatar
somethingclever
If you are on a tight budget you should run the original bolts and put your ARP head bolt money elsewhere.
Old Nov 7, 2016 | 08:07 AM
kwe45919's Avatar
kwe45919
^^^ This is smart advice......stock bolts should work....but in the case they are needing to be replaced or for piece of mind, replace with grade 8 bolts.....
Old Nov 7, 2016 | 08:28 AM
jbehuniak's Avatar
jbehuniak
Agree bolts should do fine. Studs make the head install easier if your engine is on a stand. but removing the head in the truck with studs could be an issue.
I did studs on my build but from everything I have read it is overkill.
Old Nov 7, 2016 | 09:34 AM
Kyle Wood's Avatar
Kyle Wood
Id rather be safe but i think the bolts would be fine aswell but wanted to hear it from other people.
I wouldnt do the original head bolts because of how old they are and the fatigue stresses they have been through. you are asking for problems that i dont want to work on later. That also goes with grade 8 bolts. They may have a high tensile strength but not a high fatigue rating so they may break or stretch over many cyclic repeated loading and unloading. ARP bolts/studs are a must for head bolts/studs. why skimp with something that keeps your engine combusting chamber closed.
Old Nov 7, 2016 | 09:35 AM
Kyle Wood's Avatar
Kyle Wood
now i just have to find those bolts again...
Old Nov 7, 2016 | 10:03 AM
MikePacey's Avatar
MikePacey
Unless you are spraying or running some sort of boost you don't need studs. But also on that note you can get flea bay arp knock offs cheap and they will hold if your wanting to have the "look" of studs.
Old Nov 7, 2016 | 10:17 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Here you go:
ARP - cylinder head bolts ARP 351m/c 400 154-3604 #154-3604
Old Nov 7, 2016 | 09:10 PM
Kyle Wood's Avatar
Kyle Wood
Thanks man! i actually already found them but i think these are actually a bit cheaper!
Bubba Jones
May 26, 2017 02:22 PM
ihf-350
Jun 2, 2015 05:58 PM
wtroger
Nov 29, 2011 08:42 PM
76 F150 Ranger XLT
Sep 15, 2004 12:53 PM
JJDDOOGG
Dec 21, 2002 02:37 PM
