head bolts
Old Nov 29, 2011 | 12:21 PM
wtroger's Avatar
wtroger
head bolts
When rebuilding a 7.3 should you use new head bolts?
Old Nov 29, 2011 | 12:43 PM
1994F2507.3L's Avatar
1994F2507.3L
i would but thats just me. im gonna rebuild for more power though so im still in the debate over new head bolts (Victor Reinz) or studs (ARP) if the victor rienz bolts will hold up to 15lbs boost then i'll probably go with them..... there 70 bucks from autozone
Old Nov 29, 2011 | 01:18 PM
1BadB2's Avatar
1BadB2
just get studs. Its well worth it.
Old Nov 29, 2011 | 01:30 PM
joshofalltrades's Avatar
joshofalltrades
new bolts are always recommended, as they usually stretch a little while being installed. but that said, some people have successfully used the same set of bolts 3 or 4 times. i consider the cost of redoing the whole job compared to the cost of new bolts and usually choose new bolts
Old Nov 29, 2011 | 06:58 PM
wtroger's Avatar
wtroger
Anybody have the victor part number.
Old Nov 29, 2011 | 07:56 PM
greywynd's Avatar
greywynd
Actually if you are doing a stock rebuild there's no need, these are not a torque to yield head bolt like are used in some engines these days.
If, on the other hand, you are looking to upgrade, add a turbo, etc, then it's well worth it to consider a set of studs while you're at it.
Old Nov 29, 2011 | 08:16 PM
starmilt's Avatar
starmilt
What greywind said.
Old Nov 29, 2011 | 08:42 PM
boggerted's Avatar
boggerted
Only TTY (torque to yield) bolts need to be replaced, such as the ones used in 6.0s. Youll be fine with reusing them
doom899
Nov 11, 2022 10:47 PM
Bubba Jones
May 26, 2017 02:22 PM
Kyle Wood
Nov 7, 2016 09:10 PM
ihf-350
Jun 2, 2015 05:58 PM
JJDDOOGG
Dec 21, 2002 02:37 PM
