ARP bolts
Old Dec 19, 2002 | 09:31 PM
JJDDOOGG's Avatar
JJDDOOGG
ARP bolts
Im trying to find head and main bolts for my 400M.
All I can find from ARP are bolts and kits for the 351C.
Are the bolts the same? Im sure someone has come accross this before.
Thanks.:P
Old Dec 20, 2002 | 08:50 AM
shazam's Avatar
shazam
ARP bolts
Yes there the same on both the 351C and the 351M/400
Both heads and mains caps....
Old Dec 20, 2002 | 08:56 AM
chris eck's Avatar
chris eck
ARP bolts
Have a set of ARP rod bolts #154-6001 SB FORD 351m-400 190,000psi.These are new still in the package as this is what the label says.Hope this also helps.
Old Dec 20, 2002 | 10:56 AM
beartracks's Avatar
beartracks
ARP bolts
A word of warning. I used ARP head bolts and due to their harping about it I also used their "special" graphite lube on one engine. Lose the lube! I could not get the bolts to tighten the head down at 110# of torque. There was too much friction. I had to clean everthing out and go back to oil.
Old Dec 20, 2002 | 07:45 PM
fatdaddy's Avatar
fatdaddy
ARP bolts
I was under the impression that the graphite was a Lubricant and supposed to facilitate torqueing the head bolts to the proper value....and..are you are saying that it made it impossible to torque the head bolts too the 110 ft.lbs .....that's kinda hard to explain....I'll have to remember that!!!!!thanks , fd
Old Dec 21, 2002 | 02:19 PM
beartracks's Avatar
beartracks
ARP bolts
Me too. It's something to be carefull about.
Old Dec 21, 2002 | 02:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
ARP bolts
