"Not much call for 15's anymore"..
That's what I've been told by 2 wheel companies when trying to buy a certain wheel for my '84 2WD. So..looks like I'll go to 16X8 instead of stock 15X7. I can get correct pattern/backspace on 16's. What would be the best tire size for the 16s ? This is just a driver truck..thanks..j.
Jer - I'd go to Tire Rack and look at tires by size and select your current size. Pick several, like maybe 4, and hit "compare". That'll bring up a page with specs, and note the rolling diameter of them. Then go tell it you want 16's and pick a size. Pick several and compare, and then adjust size up/down to get the same rolling diameter.
Also, they have a section where you can chose another wheel and tire for your vehicle. Do 16's and I think it may tell you what size you should have.
For instance if you were running 235 75 15 inch tires before, you can also run a 235 70 16 and be very close to the same diameter and tread width as the 15 inch tire.
235 is the tread width in mm. 75 is the height of the sidewall, which is a precentage of the tread width. So with a 235 75 15, the sidewall is 75% of 235mm. So if you go to a 70 series tire, the sidewall is only 70% of the tread width, which works out well with a larger diameter rim.
girlwithatruck
06-16-2011 10:22 PM
gr8199
02-08-2002 01:15 PM
