Bullrsix
Old Nov 6, 2016 | 10:14 PM
Bullrsix's Avatar
Bullrsix
Bullrsix
99 Expei won't start when temperature is 65* f. or lower
Old Nov 7, 2016 | 08:42 AM
alloro's Avatar
alloro
The engine won't turn or it won't fire up?
Old Nov 9, 2016 | 07:15 PM
Bullrsix's Avatar
Bullrsix
I should of explained better. It does turn over, have to give it gas and keep foot on pedal; anywhere from 1 to 5/10 min depending on outside temp. the colder the longer. Have no problems with it in warmer/hot Temps
Old Nov 9, 2016 | 08:25 PM
alloro's Avatar
alloro
How many miles on it and at what mileage were the spark plugs last changed?
Old Nov 10, 2016 | 12:00 AM
Bullrsix's Avatar
Bullrsix
183k purchased 2010 w/140k not sure when or if plugs changed. replaced alternator and starter have added injector and engine treatment
Old Nov 10, 2016 | 08:55 AM
alloro's Avatar
alloro
My navigator had 150K on it when I experience the same problem as you. As it turns out the previous owner never changed the spark plugs at 100K making them 50K overdue. I changed the plugs and it has started and run like a champ ever since, no matter how cold out it was. I have a thread on it somewhere around here, I'll look for it.
Old Nov 10, 2016 | 09:00 AM
alloro's Avatar
alloro
Found it: https://www.ford-trucks.com/forums/1...ing-issue.html
fordf350man
Apr 1, 2017 11:55 PM
nickdellamore
25
Aug 11, 2010 01:57 AM
78fordf150ranger
Dec 22, 2005 11:41 AM
Fitzford
1983 - 2012 Ranger & B-Series
Feb 3, 2005 06:45 PM
nightcrawlermc
Bronco II
18
Nov 13, 2003 06:21 PM
