6.leaker help
Old Nov 6, 2016 | 07:02 PM
jslimAU57's Avatar
jslimAU57
6.leaker help
Ok. As stated in my welcome thread, I just bought a 6.0 two weeks ago. It is a 2007 with 162k on the clock. The PO says he put an egr delete, updated oil cooler, upgraded FICM, cleaned turbo and HPOP among other things. The other day I noticed a few drops of oil on the driveway. He said it wasnt leaking when he had it and its now in the shop. My mechanic has the top of the motor off and I am about $600 in the hole and he doesnt know where the leak is coming from. He wasnt to keep breaking the motor down. There was a few drops coming down the front onto the front axle and steering damper and a bit coming off the back near the bell housing. Anyone have any ideas? We have ruled out the IPR, ICP, HPOP, and CAC. It runs and drives fine. Leaks just drive me nuts. Thanks in advance.
The first few pics are underneath the truck. The 2nd is of the valley with the top end off then looking down the front.
Old Nov 6, 2016 | 07:10 PM
BLADE35's Avatar
BLADE35
Id get it out that shop RUN LIKE HELL
Looks like front cover but it so bad it need cleaned up before Diagnostic IMO
It needs pressure washed what a Mess
Old Nov 6, 2016 | 07:12 PM
jslimAU57's Avatar
jslimAU57
Thats what I figured. I shouldnt have let him take it apart with out knowing something.
You say it looks like the front cover? Can you elaborate?
Old Nov 6, 2016 | 07:13 PM
BLADE35's Avatar
BLADE35
Id tell him to put it back together and get out of there F-him
WatsonR's Avatar
WatsonR
HPOP cover. It uses a specific type RTV, if he skimped on the type, it will leak.
It also looks like you could have a EGR delete leak... that looks to be a heater hose
Old Nov 6, 2016 | 07:16 PM
jslimAU57's Avatar
jslimAU57
Oh that EGR Delete was definitely leaking. That clamp was loose as all get out.
Old Nov 6, 2016 | 07:19 PM
BLADE35's Avatar
BLADE35
Look at all the crap caked to the belt tensioner and everything around there
The top bay is dirty where turbo and stuff was but heck a lot cleaner then belt area
But the belt area is a Trainwreck
Old Nov 6, 2016 | 07:21 PM
BLADE35's Avatar
BLADE35
it don't look to bad where the oil press sensor is pulled so again points to front cover
the tops just to clean for the mess around belts
we need one more pic of the oilk filter house area see if oil going down there I suspect its Not
jslimAU57's Avatar
jslimAU57
I know. It was the one place I forgot to look before purchasing. Oversight on my part.
Old Nov 6, 2016 | 07:49 PM
BLADE35's Avatar
BLADE35
Looks to be the crap on top good call
You need an OEM hose there that one will cause issues
Old Nov 6, 2016 | 08:08 PM
WatsonR's Avatar
WatsonR
In the forth picture, the passenger side HPOP cover, it's pouring down the valley toward the front of the motor AND with the truck stance sloped to the front, over time, it would drain to the front.
Take some de-greaser to that oily mess and clean it up, use the garden hose to rinse it off.
Old Nov 6, 2016 | 08:11 PM
jslimAU57's Avatar
jslimAU57
You can tell that from the picture? That's great! So I need go replace the gasket in the HPOP?
Old Nov 6, 2016 | 08:17 PM
WatsonR's Avatar
WatsonR
Let a couple more guys look before you get overly happy. I'd redo the HPOP cover with a new gasket and the correct RTV AND a new hose and clamps on the EGR delete.
AND then clean it up.
Old Nov 7, 2016 | 06:20 AM
jslimAU57's Avatar
jslimAU57
Well, I wouldnt call it "overly" happy. I have to get it out of this guy's shop. So I'll do what you suggested and if the leak persists, I'll take it somewhere else. I dont mind leaks, just when they create puddles.
Old Nov 7, 2016 | 06:44 AM
WatsonR's Avatar
WatsonR
I think that's the right call... the leak is up high.. lets think out loud.
Both right and left side pictures have oil at the top that looks wet, further down the oil looks caked with grime. That wet oil picks up road dust, looks like grit of all types, if it were the front cover it would be dripping from the pan a little more, not covered by dust, unless the leak was lower... its not, the leak is high.
The drivers side heads are covered with it, its at least that high and a front cover leak, most likely, wouldn't spray the heads. And the passenger side in picture 5, the oil is still wet... no dust stuck to it because its washing it down. An oil return line from the turbo would look like a waterfall and you said it was coming off the back some... that leaves the HPOP cover.
PO said it didn't leak.. sure... but it did get HPOP work and that is a known issue if the wrong RTV was used.
