6.leaker help
Old Nov 7, 2016 | 09:18 PM
  #31
jslimAU57's Avatar
jslimAU57
The oil filter housing (the cylindrical part) was not torqued to spec. It was hand tightened and and one was loose. The o-ring was basically flat on the bottom part where the cylinder connects to the cooler. Also, a fitting was loose. I had the cover gasket replaced, the O-ring, and the oil pressure switch replaced.
Front cover wasnt loose and that cooler gasket was, in fact, bad.
Old Nov 11, 2016 | 06:29 PM
  #32
jslimAU57's Avatar
jslimAU57
Just got her back. Everything is back to normal on the leak front so far. She seems to be idling a bit rough in drive and shaking a bit while accelerating. But it may just be me.
Thanks for your help guys.
treyw147
Nov 22, 2017 07:50 AM
David Fehir
Aug 1, 2017 03:01 PM
Thor'sHammer
Jul 28, 2015 03:30 AM
ATGLLC
Nov 1, 2009 05:43 PM
JAYSF350
Oct 17, 2009 09:29 PM
