No run without either
Old Nov 6, 2016 | 03:20 PM
dondolittle2's Avatar
dondolittle2
Thursday coming home my 7.3 quit just like ran out of fuel,changed fuel filter still no run. Changed hpfp engine turns over no run. Temp 70^ in my garage, batteries good, one small squirt either engine runs great, No check engine light, nothing. Help I need my truck
Old Nov 6, 2016 | 04:43 PM
DieselDenny's Avatar
DieselDenny
Check your framerail under drivers seat. Have someone close the door and key it on. Your fuel pump is there. If it's singing, you may have other issues.
Is your oil topped off?
Where is your fuel level at?
Check your pump first.
Odd but happens, check fuse #30 under dash and see if it's blown. That's for the fuel bowl heater. If it's popped, reach down below and behind the fuel bowl and unplug it, then replace the fuse. You don't need it.
Post on your findings. We'll get this.
Denny
Old Nov 6, 2016 | 05:26 PM
cjfarm11's Avatar
cjfarm11
You have a fuel delivery issue. Check fuel prsseure and move on from there
Old Nov 6, 2016 | 06:34 PM
z31freakify's Avatar
z31freakify
Remove the fuel line from the fuel pump and apply air back to the tank to see if your strainers arnt clogged.
Old Nov 6, 2016 | 06:49 PM
nlemerise's Avatar
nlemerise
Lay off the ether.... bad news.
Old Nov 6, 2016 | 10:21 PM
retiredsparky's Avatar
retiredsparky
You will be without that truck for a long time if you keep using ether. Glow plugs plus ether=big boom+lots of big parts become very small parts.
Old Nov 7, 2016 | 07:21 AM
Jaime74656's Avatar
Jaime74656
Also check the cps, it's a 10 min job, always good to keep OEM spare if that is not the issue.
What diagnostic equipment do you have? Numbers will help so we're not launching buck$zooka rounds blindly hoping to hit somthing…also there should be a big warning sticker about not using either to start the truck…I suggest you heed the warning before the truck is turned into a paper weight…
Old Nov 7, 2016 | 08:00 AM
ExPACamper's Avatar
ExPACamper
Ether and diesels are not a good combination. It can be done, with minimal risk, on equipment WITHOUT GLOW PLUGS.
With glow plugs, they can ignite the ether, without regard to firing order, ignition sequence, injectors firing, etc.
Sort of like Godzilla stepping on your camshaft- all the lobes are driven down at once Of course, the camshaft being very strong, it's often the "other" things pushing them, like pistons, push rods, rings, cylinder walls, valves, rockers, springs, etc that take the real beating. None of it good.
If you MUST diagnose with ether, unplug your glow plug relay/wiring, depending on your model.
ranger9010
Oct 1, 2013 03:52 PM
kemorris
May 6, 2012 09:15 PM
capitanjo
20
Nov 24, 2011 03:18 PM
goatro
Aug 16, 2009 08:15 PM
messeswithtrux
Feb 11, 2008 09:22 AM
