Reverse lights wired to upfitter switch
Old Jul 20, 2018 | 12:47 PM
klassic's Avatar
klassic
Originally Posted by hollapm
Great information posted. Is it possible to wire in reverse aux lights to an up-fitter switch so that they are:
always off (so not to put out too much light while camping or close to an object)
On in reverse
Always on (when needing to light up a camping spot)
in thinking out loud I think that it would have to be set up with 2 up-fitter switches to accomplish this since none of the up-fitters are dual pole. So switch one on works with reversem switch 2 is aways on and all switch one and two off is always off. Is there another way to do this?
here is how to shut them off, if that interests you.
reverse lights off
just off the top of my head, if you want to turn them on then use a second relay wired to a second upfitter and wire the relay with the bulb side of the green/brown wire to pin 30 and the other end of green/brown to pin 87a... then add a 12v source to pin 87..
I didn't put too much thought into that, but it should work.
Old Jul 21, 2018 | 12:48 AM
hollapm's Avatar
hollapm
I think that I am missing something but relays aren't my speciality ;-(
____________30 12+ volt battery
____________85 ground
Relay 1 _____86 up-fitter switch 1
____________87 Aux lights
____________87a green/brown wire (with diode?)
____________30 green/brown wire to relay 1
Relay 2 _____86 up-fitter switch 2
____________87 12+ volt battery
____________87a not used
Old Jul 21, 2018 | 09:12 AM
klassic's Avatar
klassic
hollapm, are you talking about auxiliary back ups AS WELL as the Ford reverse lights? To all turn on as one, and all turn off as one?
Old Jul 21, 2018 | 09:27 AM
hollapm's Avatar
hollapm
This is what I was thinking.
Switch 1 and 2 off: Aux off
Switch 1 on, 2 off: Aux lights on
Switch 1 on or off and switch 2 on Aux on with reverse lights
This way i don't have to have the Aux turn on when I go into reverse every time (but can control it when I need it) as well as control if when stationary to turn on or off.
Old Jul 21, 2018 | 09:49 AM
klassic's Avatar
klassic
ok.. I thought you wanted to shut the reverse lights OFF when backing up the trailer, and turn ON reverse lights anytime you want.
Old Jul 21, 2018 | 09:50 AM
Readgriff's Avatar
Readgriff
Upfitter switch tail lights
Originally Posted by RightWingNutJaob
I have supplemental reverse lights that I use to illuminate my trailer when hitching up at night. They normally come on with the regular reverse lights.
I wired up one of the upfitter switches so that I could turn the reverse lights on without having to shift the transmission into reverse.
(It's not legal, but I have, on occasion, used the reverse switch to show my annoyance to folks who are tailgating me, and to signal meathead drivers who are behind me at night with their Hi-Beams on.)
This would be very handy to do is all the instation done under the hood?
Where would the diode be installed and splices in the reverse light wire and upfitter switch.
I have 2017 Superduty F350
Do you have any pictures of your installation?
Thanks
Readgriff
Thanks
Old Feb 1, 2020 | 09:22 AM
coues7's Avatar
coues7
Trailering
Originally Posted by RightWingNutJob
Literally, it's nothing to look at. There is a Diode that's now in line with the existing wire, and the upfitter wire is spliced after it.
I cut the Reverse wire going to my trailer connector. Then soldered the Anode end of the diode to the Ford wire that comes from the front of the truck. Then I soldered the other end of the cut Ford wire to the Cathode side of the diode. (The Cathode side is marked with a white stripe.) From there, I also soldered my new upfitter power wire to the Cathode side of the diode. The wire then goes to my supplemental reverse lights.
The Diode and the solder connections are covered in shrink tubing, and I put it into a piece of split wire-loom. It looks like any other wiring under the truck.
@RightWingNutJob so is there no need for a relay in this setup? I also saw THISthread and was going to match it, but then I realized there could be feedback.
Old Feb 1, 2020 | 09:47 AM
crewzer's Avatar
crewzer
Lightbulb
Activating the back-up lights from an U/S can be done without a diode:
Install an automotive SPDT relay controlled by the upfitter switch and relay
Connect the back-up lamps to the relay Common terminal
Connect the truck’s original back-up circuit to the relay NC terminal
Connect the +12 output circuit from the upfitter switch relay output to the relay coil and the relay NO
Install a reverse-polarity flyback diode and load resistor across the relay coil terminals
With the U/S OFF, the new relay will be de-energized and the back-up lamps will operate nominally from the original truck circuit through the relay’s NC and Common terminals.
With the U/S ON, the relay will energize and interrupt the NC circuit, this isolating the original truck circuit. The NO circuit will close, providing +12 to the back up lights.
This should work. I’ve done similar circuits before, but not this exact application.
HTH,
Jim / crewzer
Old Feb 1, 2020 | 10:23 AM
coues7's Avatar
coues7
Trailering
HTH,
Jim / crewzer
@SDcrewzer thanks. Based on that description the relay serves as the diode to prevent backfeed correct?
Old Feb 1, 2020 | 10:29 AM
crewzer's Avatar
crewzer
Essentially, yes. By opening the NC circuit, there’s no back feed from the Common terminal.
HTH,
Jim / crewzer
Old Mar 19, 2021 | 08:20 PM
coues7's Avatar
coues7
Trailering
So I completed this install using a relay and then had a new bumper installed. After the install my upfitter switch prevents the lights from coming on instead of turning them on. I can put the truck in reverse and my factory lights and added lights come on. If I leave it in reverse and flip the up fitter switch switch the added lights turn off. When not in reverse the switch does nothing. Did something short? I replace the relay and still have the same results.
Ricky Melton
Escape & Escape Hybrid
Mar 11, 2019 08:16 AM
ssande
Jun 22, 2017 10:20 AM
Seanosu
Mar 7, 2016 09:59 PM
mikeyt4e
Mar 7, 2015 05:12 PM
bkks744
Jul 7, 2008 06:10 PM
