Reverse lights off mod
Old Mar 29, 2017 | 01:52 PM
klassic's Avatar
klassic
I posted before in the thread about what to use upfitter switches for and I said I was using a switch to shut off the reverse lights when backing up my 5ver at night. The lights are blinding from the reflection.
Some asked how I did it. Well I finally got around to it.
The connector for the reverse light wire is at the back passenger side mounted to the trailer hitch bracket beside the spare tire. Big grey connector.
Pin 7 green/brown.
The underside of the truck isn't the best spot to be splicing and cutting wires, but I can't find the wire anywhere else. I think I see it under the master brake cylinder, but impossible to get to.
I got a waterproof Bosch style relay and spliced 87a in line with the green/brown wire.
Grounded the relay to pin 1 or 11 (blue)
Ran a wire in split loam from an upfitter wire to the back along the passenger side (avoid the exhaust)
Now I can shut off the reverse lights with my upfitter 1.
Old Mar 29, 2017 | 03:41 PM
bikerman5345's Avatar
bikerman5345
This looks like a great idea. I will be doing this. Thanks for the info.
Old Mar 29, 2017 | 04:22 PM
Johnpsz's Avatar
Johnpsz
subscribing, I added reverse lights to my 5th wheel and wonder if dropping them from the truck like this will kill them in the trailer, but would be worth a try as you're right, the reflection doesn't help backing at night.
Old Mar 29, 2017 | 07:02 PM
klassic's Avatar
klassic
Good point.
I have them on my trailer too. I haven't tested your theory yet.
But I do know on my 2012 I shorted out a trailer backup light and blew the "trailer reverse light" fuse. That's all the fuse was for.
I can only assume it's the same on the 17.
Plus, at the connector pin 7 coming in is a 14g. Pin 7 on the other half is a 18g going to the lights. I'm sure it's not making a pit stop at the 7 way trailer plug only being 18ga
Old Mar 29, 2017 | 07:16 PM
klassic's Avatar
klassic
Here's the weather proof relay I used. Seems to be sealed up pretty good
https://www.amazon.ca/gp/product/B01JBQR2Z4/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1 https://www.amazon.ca/gp/product/B01JBQR2Z4/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
Old Mar 29, 2017 | 07:25 PM
klassic's Avatar
klassic
I guess I should mention this was done on a Platinum with LED lights.
I don't know if the wiring is the same for non LED lights.
One would assume it is.
Old Apr 2, 2017 | 09:37 AM
porthole's Avatar
porthole
This has been on my to do list since I bought my 2011 .....
Still haven't done it with the thought - I am trading the truck in soon ...
Old Apr 2, 2017 | 09:45 AM
porthole's Avatar
porthole
USA version of the relay link USA version of the relay link
Old Apr 30, 2017 | 10:02 AM
Stout17's Avatar
Stout17
Klassic, have you check to see if the trailer reverse light still work yet? Great mod..it's on my list now.
Old Apr 30, 2017 | 10:31 AM
klassic's Avatar
klassic
Yes. All is fine.
Sorry I forgot to post the results.
I have used it 3 times now. It makes a big difference.
Old Apr 30, 2017 | 05:22 PM
Stout17's Avatar
Stout17
Awesome, thank you for the reply
Old Oct 13, 2017 | 09:55 PM
klassic's Avatar
klassic
Thought I would bump this thread in case any new members are interested.
It really helps when backing up a trailer in the dark
Old Oct 13, 2017 | 10:34 PM
First Dually's Avatar
First Dually
I'm glad you bumped this! I'm new to the forum and really like the idea. Thanks!
Old Oct 14, 2017 | 05:54 AM
Xwild's Avatar
Xwild
I've gotta do this mod. I bought my relays.. just haven't had time to do it.
Old Nov 10, 2017 | 07:11 AM
Bugler's Avatar
Bugler
Thank you. I recently purchased a 2009 F350 SD with a 5th wheel hitch already installed. Still need to purchase a 5th wheel but it will be good to get this out of the way.
