Need help please,
Old Mar 19, 2021 | 06:38 PM
Rcmadman43's Avatar
Rcmadman43
Need help please,
Started my f350 tonight, check engine light came on, it threw 6 problem the pcm could communicate with abs module, seat restraint module, steering wheel module, and a few more, truck worked and drove fine , but light stayed on , I could use some of your guys opinions
Old Mar 19, 2021 | 07:17 PM
4wd6.7L's Avatar
4wd6.7L
I often see posts with recommendations to check the batteries first when this type of issue happens. Another source that can cause similar symptoms is water intrusion into some of the connectors under the bed, at the rear of the truck.
Old Mar 19, 2021 | 07:24 PM
Ding126's Avatar
Ding126
what year truck, miles etc
Old Mar 19, 2021 | 07:55 PM
Rcmadman43's Avatar
Rcmadman43
2019, I haven't driven the truck in the rain in long time, its stored all winter , I have driven it multiple times since pulled out of storage with no issues. I got a powertrain fault on Saturday ( the wrench) it went away after 10 minutes and tonight I get the check engine light
Old Mar 19, 2021 | 08:28 PM
BenFranklin's Avatar
BenFranklin
Shooting from the hip, sounds like water intrusion in underhood fusebox. There is a TSB out for it relating to the cover not sealing and water getting in, causing all kinds of crazy mayhem.
Try this video, worth a look.
C12H24's Avatar
C12H24
You might have rodent problem.
Old Mar 19, 2021 | 08:34 PM
4wd6.7L's Avatar
4wd6.7L
https://www.youtube.com/watch?v=STC3LWCHoPQ
Except that the TSB only applies to 2020-2021(for some reason).
Old Mar 19, 2021 | 08:37 PM
Joe T's Avatar
Joe T
Rodents was my thought too
Old Mar 19, 2021 | 08:44 PM
Rcmadman43's Avatar
Rcmadman43
Rodents where, I have opened the hood and didn't see any signs of anything
Old Mar 19, 2021 | 08:48 PM
Ding126's Avatar
Ding126
I would start by checking all the harness connectors around the spare tire..Use electric cleaner and add dielectric grease to all connectors.. corrosion / moisture is possible.
Then I would check batteries, One or both could have issues..or just replace them.
check engine compartment for possible rodent damage
Good luck and report back
Old Mar 19, 2021 | 08:49 PM
BenFranklin
Originally Posted by 4wd6.7L
Except that the TSB only applies to 2020-2021.
My mistake, overlooked that. Guess that's what I get for shooting from the hip LOL. I had just watched that video recently and it seemed to fit the bill.
Old Mar 19, 2021 | 08:53 PM
Rcmadman43's Avatar
Rcmadman43
The batteries could be bad ,its only 2 years old and had 15000 miles on it, I have driven the truck 3 times this week, I did remote start the truck tonight then this all happened. I dont know if that makes a difference
Old Mar 19, 2021 | 08:58 PM
4wd6.7L's Avatar
4wd6.7L
Honestly I'm not sure why only those years, I think the 17-19 have that part in the same or similar place. Maybe its a factory installation error on the 20+.
He's not one for words in the comments, but someone asked if that could happen on their 19, his response was no, only 20. 🤷🏻‍♂️
turbogus
Sep 19, 2020 01:05 AM
wiredgeorge
May 19, 2019 06:47 PM
85F350IDI
Mar 3, 2016 04:27 PM
f15olandscape
Apr 6, 2015 10:32 PM
