2.7 EB Problems?
Old Nov 6, 2016 | 11:52 AM
raytasch's Avatar
raytasch
Believe Nothing
2.7 EB Problems?
This 2.7 EB has been out long enough that any "teething" problems should have surfaced by now. Folks should have lots of miles on some of them. I am thinking of buying a truck with one. So the question is: What problems have surfaced? Any high mileage reports would be appreciated, as well.
TIA
Old Nov 6, 2016 | 01:01 PM
GlueGuy's Avatar
GlueGuy
I haven't heard of much, if anything. The 2.7L ecoboost is a pretty stout design. It is an incremental improvement over the lessons learned with the 3.5L ecoboost, and although that engine had some teething problems, it has turned into a very reliable workhorse. The improvements that made their way into the 2.7L ecoboost were, in turn, incorporated into the second generation 3.5L ecoboost.
I have friends with the 2.7L EB, but they are all relatively low mileage at this point. However, none of them has had any issues.
Old Nov 6, 2016 | 01:28 PM
raytasch's Avatar
raytasch
Believe Nothing
Exactly! By this time into the release, the 3.5 EB had the problems well documented and most resolved. If the 2.7 has known problems I will opt for a 3.5L or 5L. I don't have the temperament anymore to go through "teething" problems.
Thanks for the reply.
Old Nov 6, 2016 | 04:21 PM
JKBrad's Avatar
JKBrad
I don't think the new 3.5 EB and the 2.7 EB have much if anything in common. If anything, the 2.7 EB has more in common with Fords Lion family of diesels than anything else. The 2.7 is a very overbuilt gas engine. I was disappointed that the new 3.5 EB wasn't similar.
The 2.7 could easily be reworked to function as a diesel or a gasoline direct compression ignition engine. Essentially a gas engine that runs like a diesel, which is where the 2.7 EB is probably going.
Old Nov 6, 2016 | 07:11 PM
Frdtrkrul's Avatar
Frdtrkrul
Only issue I heard was with the Start/Stop feature. Member on here posted a video on YouTube as unlisted (meaning need the link to see it) but I haven't been able to locate it.
Old Nov 6, 2016 | 08:19 PM
Beechkid's Avatar
Beechkid
I don't know about issues being well resolved.......coking in the turbos, that is something that unless you are running the highways is just going to happen and there is no way short of a complete twin turbo dismantle to handle that...not to mention, running 16 psi boost is extremely high in any engineers book...although for has this well managed, if the ecm or other related systems hick-up for a split second, catastrophic engine failure is an almost certainty.......and fuel mileage, reality, the same of less than a V8.
Old Nov 6, 2016 | 08:39 PM
Papa Tiger's Avatar
Papa Tiger
Ah, well you got most of that completely wrong. https://www.ford-trucks.com/g/picture/5845922 11,300 miles on mine in 3 months.
Old Nov 6, 2016 | 08:45 PM
Tom's Avatar
Tom
I can only recall one or two turbo replacements that I've ever heard about over the years, and those were wastegate failures if I remember right. Seems rare to hear about engine failures as well. Am I looking in the wrong places?
Old Nov 6, 2016 | 08:51 PM
Papa Tiger's Avatar
Papa Tiger
Some tuned trucks with undocumented abuse mostly that broke 3.5 EB motor mount areas of the engine block and some early ones may have injested some water from the CAC.
Old Nov 7, 2016 | 02:16 PM
airm4n's Avatar
airm4n
Just about at 7000km on my 2016 f150 4x4. Engine runs good. Loud little sucker though at idle sounds like a diesel. Changed the oil yesterday and found that I don't care for the stupid tray covering the spout or for that matter the plastic spout either was on so tight I had to put a pair of pliers on it. That and it takes close on 40 minutes to change oil. Added 5 liter jug checked the dipstick and it was bone dry. Takes 15-20 minutes for the oil to drain down to check. You start the engine and shut it off check the dipstick and dry again. Gotta wait again. Thats my only complaint which isn't that big of a deal. Ended up taking somewhere between 5 1/2 liters to 6 liters of oil. Fuel mileage is great unless you are pulling hard we are averaging 19.5 mpg I did one longer trip on flat ground but hit a really hard wind. That kicked me down to 15.5mpg.
Old Nov 7, 2016 | 03:15 PM
raytasch's Avatar
raytasch
Believe Nothing
Thanks for the feedback guys. I am scheduled to pick mine up tomorrow.
Old Nov 7, 2016 | 03:25 PM
limuel's Avatar
limuel
Premium gas for 2.7 EB
I'm still a newbie in trucks, I heard someone that if you have an turbo you should only use premium gasoline is that correct? Thanks in advance for your help guys ! We own a 2.7EB F150
Old Nov 7, 2016 | 03:30 PM
raytasch's Avatar
raytasch
Believe Nothing
That is old school thought. Modern engine management systems control timing and the 2.7Ls are designed to run on regular fuel. If you want to run a tuner on the engine you can use premium fuel and get more performance.
Edit: Welcome to the forum.
Old Nov 7, 2016 | 03:36 PM
limuel's Avatar
limuel
Greatly appreciated,godbless!
Old Nov 7, 2016 | 09:42 PM
Papa Tiger's Avatar
Papa Tiger
Or you can get a sport model with 3 factory tunes and relax an just enjoy their performance.
