Slow start when warm is usually an indication of your timing being set too high, your starter on its way out the door, or your battery is also on its way out the door.
Running 2 solenoids just for a "hey why not" factor is a great way to justify carrying a fire extinguisher in the cab everywhere you go.
Are you running headers on your truck? You may be heat soaking the starter after running. You might consider a heat shield of some sort or they make wraps for your starter to insulate it from the heat. Is it a new or newer starter?
