6.9 Build
So far here's where I'm at.
Gen1 Banks non-wastegate turbo with 3" exhaust.
Mahle .040 ceramic coated (R&D) .010 decompress pistons.
Stock heads rebuilt with 7.3 turbo valves on the exhaust. (Stellite)
Comp 910 springs?
ARP head studs
Balanced rotating assembly
Stock rebuild otherwise.
Stage 1 cam
90cc pump (R&D)
Stage 1 injectors.
Truck is also being converted to a T19 and has 3.55's and 33's. 4x4. Not looking to set any records, just a good tow rig that's reliable. 2xx at the wheels would be nice, but close is good too... 5xx or so on TQ.
A 110 pump might be better, but my wallet will dictate that. There's about a $500 difference...
Thoughts?
Also, since I'll be using the 6.9 NA rods, does ARP make bolts for them and is that needed?
TIA
This will fit the Banks turbo fine; it isn't going to want to do more than that really.
This also will reduce your fuel need - 90CC should be fine for that. A 110 is overkill until you can get at least 15 PSI of boost at a reasonable temperature(intercooling probably needed).
If you are looking at that, you can probably skip the ceramic coating(I've run my 7.3 at 950-1100 degrees for a few hours and the pistons looked just fine - they have plenty of oil from the bottom).
Comp 910 or Trick Flow valve springs... probably not needed unless you get a bigger turbo. I didn't need them until I managed to get 20 PSI out of a TE06H and the drive pressure was a /lot/ more than that.
I would say that the #1 thing I'd be making sure of is valve clearance. Especially with a rebuild and extra-tall cam, if the machine shop doesn't make the tolerances on valve recession to spec, you'll hit the pistons and destroy your guides in short order.
That's just my 2c worth.
Yeah, the banks will probably run out of steam around 8-10 I'd expect. If that. Might be 6-7psi, but I'm just going on hearsay from others. 90cc sounds like a good fit for now.
I'm curious about the limits of boost though. I would think I could go higher than 10 with studs. I know they're smaller, but 10 isn't a ton when you've got 7.3's running 30,40 and even 50psi. I'd be curious to see what Mark Strock's running. I know he went a bit overboard building his 6.9...
Because of budget I'm getting the heads and block done separately and I'm going to mate them. I figure that gives me a chance to degree the cam and I can even pull a couple valve springs and check clearances. I can bring the heads back and have them cut deeper if need be.
I wish I knew who in the SE PA area I could trust to put it all together right, but I don't... Mark went to Washington so that tells me something...
Side story, I was busy and people always tell me I need to let others do things for me. So I called a company out to "tune up" my oil heater in my house. Weather got cold and after the 3rd no start when I called to bitch I was told that the .5gph nozzles were prone to clogging and that they'd send someone over to swap it for a bigger nozzle. I went down and pulled the gun out and by eye I knew the igniters were WAY out. Spec is 5/16" above and they were 1/2". They were supposed to be 1/16" forward, they were 1/16" back. Too high, too far back and by eye at arms length in 1 second I knew that. I reset them correctly and it's been running fine since. I know more than the tech and this isn't what I do for a living...
So yeah... I have major trust issues...
I'm being conservative in my recommendation, because if you blow a gasket instantly at 25, you probably don't want to run more than 12-15 for long periods of time... at least that's my thought process here.
I'm thinking that to improve this up to the 7.3 level, we need thicker studs. No way around it really.
Justin actually did drill and re-tap a 6.9 once, but ran into issues keeping the drill straight going down the holes.
I'm thinking that when I try rebuilding a 6.9 for power, I'll have to figure out a way around this - a simple drill guide block and a piloted drillbit should make it a snap.
... But this is just conjecture at this point; I've never done it.
This is why you can have 12 psi and make more power than someone at 18 psi...
Anyway, I peg the upper limit of a studded 6.9 at around 300/650 at the wheels. Maybe just a touch past that, but Justin lifted a head at 700-ish rear wheel torque.
I'd be happy with low 200's and 450-500 tq at the wheels. Basically a 50-60% increase over stock.
I'm thinking it's doable if you modify the drill to self-center more, by grinding down the first 1/2" or so of it into basically a pilot. This will keep it following the original hole instead of cutting a new one(wandering)
I'm thinking that even if you broke into the water jacket at the bottom in one spot or another, you could just put a bunch of RTV in there and call it good. Just as long as you have a minimum of 3/4" or so of thread engagement, you should be fine -- remember, the threads in the block are weaker than the ARP studs - Even in a 7.3, the threads will pull out before the ARP studs break.
That's probably around where Justin was +/-
So 20 looks like the upper safe limit on a studded 6.9. At least with stock sized studs.
Add Austin Presley to the list. Digital boost gauge - it let go at 24.6psi...
Maybe we can add this to the stickies somewhere. How much boost will a 6.9 with 7/16 studs take?
Austin Arps
Austin Presley
Craig Clifton
Justin Anderson
Have all confirmed lifting a head around 25psi.
I cant remember if there are any compressor wheel options for the banks, but i wouldnt be afraid of running a 90 with a banks on a 6.9 with studs. Justin and one of the austins had little bitty turbos on there, the s256, which is a little quick and restrictive imo, especially given the headgasket issues of a 6.9, and justin was runnin the s360 with the itty bitty exhaust housing, same i think for the other austin.
Between the pistons and the cam, i think you will be fine.
I'm not looking for a million hp, just something that runs good and is reliable. If you have enough money just any amount of HP/TQ is possible. I don't have enough money...
Magnetic Drills: Free Shipping on Magnetic Drills | Drills + Drill Accessories | Power Tools | Northern Tool + Equipment
