Please help. 1996 7.5 will not start.
Old Nov 4, 2016 | 11:41 AM
Doc679's Avatar
Doc679
Hello. I need some help. I have a 1996 rv it has a 7.5 engine. ok. first off I changed the batteries, it has 3 of them 1 for the engine and 2 for the rv and they run in series. when I was changing the rv batteries there was a popping noise coming from what is called the bcc box. anyway after the battery change it started right up. drove home and shut it down.
now I turn the ignition and I just get a click. climbed under and the starter was clicking. so I replaced the starter. then tried it again and the same click. this time the sound was coming from the starter solenoid on the side of the wheelwell. so I replaced that. no luck same thing note I replaced the solenoid that is inside the bcc box. all the same.
the clicking sound is definitely coming from the starter solenoid. does anyone have any ideas.
Old Nov 4, 2016 | 10:58 PM
don-ohio's Avatar
don-ohio
Check your voltage. Maybe bad battery connections or bad wire connection at starter? don-ohio (:^)
Old Nov 5, 2016 | 07:44 AM
subford's Avatar
subford
What chassis do you have?
Is it a F53 or a E-series chassis?
In other words is it a class "A" or a class "C" RV?
Old Nov 5, 2016 | 08:16 AM
Doc679's Avatar
Doc679
It is a class A. . I cleaned all the connections that I could find. The only thing I'm thinking is the small wire off of the starter. When I bought the new starter the connections were different so I spliced them together. Maybe it's not a good connection. I will check that in a few minutes.
Old Nov 5, 2016 | 08:18 AM
Doc679's Avatar
Doc679
Class A. Only thing I'm thinking is that it might be the small wire off of the starter. When I installed the new starter the wire connections were different so I spliced them together
Old Nov 5, 2016 | 09:07 AM
subford's Avatar
subford
Most of the time the starter relay in the dog house is bad. It clicks but does not relay the power to the small wire going to the starter solenoid on top of the starter.
Your old starter and its solenoid were more than likely not bad.
Old Nov 5, 2016 | 09:10 AM
Doc679's Avatar
Doc679
Yes I changed that. I thought it was called the starter solenoid
Old Nov 5, 2016 | 09:11 AM
subford's Avatar
subford
Battery wiring example:
Old Nov 5, 2016 | 11:47 AM
Doc679's Avatar
Doc679
Can you possibly tell me which wire goes from the starter relay to the starter. I'm thinking I should replace that wire. Also, should I try and jump the starter. Meaning touch the 2 large bolts on the back of the starter to see if it turns over
Old Nov 5, 2016 | 12:19 PM
subford's Avatar
subford
The wire that goes to the starter from the starter relay is the one that is not hot with the key off.
Or it should be the one with no other wires with it on the same stud.
Looks like the one closes to you in the photo above.
JamesHajek
24
Jan 12, 2011 05:32 PM
dracip
Jan 28, 2008 06:43 PM
Marc150
13
Dec 14, 2004 04:37 PM
orockaway
Aug 28, 2004 10:31 PM
ford390gashog
Feb 14, 2004 11:54 PM
