Could really use some help
Old Nov 10, 2016 | 07:14 PM
ReBilld's Avatar
ReBilld
My rear axle wraps real bad when I get on it hard. I need to build some ladder bars. I'd say you are having the same issue.
Old Nov 10, 2016 | 11:20 PM
fordman67's Avatar
fordman67
Also check the slip yoke. Those splines may need greased a bit.
Old Nov 12, 2016 | 09:23 AM
7.3 forever's Avatar
7.3 forever
Latter bars would help but I definitely have to much upward pinion angle for sure just gotta get shims or new perches or something
Old Nov 12, 2016 | 09:24 AM
7.3 forever
I just had the slip yoke apart at the carrier and it was all good
Old Nov 12, 2016 | 10:18 AM
coreyallan01's Avatar
coreyallan01
Check the ring and pinion thoroughly...again... or you have horrible u joint bind but your at rest pinion angle
would be radically bad..
Old Nov 12, 2016 | 07:24 PM
ReBilld's Avatar
ReBilld
You need to check your springs real good then. You shouldn't have too much upward pinion angle. You need to figure out why that is before you put in shims or move the perches. Something is wrong somewhere.
Old Nov 17, 2016 | 09:21 PM
7.3 forever
I believe a lot of the upward pinion angle comes from I have 05 axles only ujoint that had been replaced in the rear was the very rear one in 216,000 but all where tight and good shape the middle one had I mean a touch of play I went ahead and ordered all new spicer life series ujoints and a brand new carrier bearing all vibrations are gone thank goodness but I ordered shims and I'm gonna try to get a set of 05 rear leaf springs to but wow driveline has so little of play now
Old Nov 17, 2016 | 09:25 PM
7.3 forever
Once again thanks guys all your guys advice made me check a bunch of other things this is why I love this website
Old Nov 25, 2016 | 07:58 AM
7.3 forever
Well I picked up a 07 f250 frame and complete running gear so looks like I've got a new set of rear leafs for my pinion shims that came in
Old Nov 26, 2016 | 01:02 AM
7.3 forever
Well got my front coilsprings in and made big difference in ride now gotta get rears swapped so I can get shims installed
Old Nov 26, 2016 | 01:16 AM
7.3 forever
Well got my front coilsprings in and made big difference in ride now gotta get rears swapped so I can get shims installed and we will be set
Old Nov 26, 2016 | 01:10 PM
nateairman's Avatar
nateairman
You did a coil swap over night!?
Old Nov 26, 2016 | 01:47 PM
  #28
7.3 forever
No I did it almost a year ago I had said earlier in post I that I had done a axle swap already
Old Nov 26, 2016 | 04:11 PM
  #29
7.3 forever
I swapped the springs out with some correct ones is what I was referring to
generalee31184
Sep 2, 2006 07:05 PM
gatesj
Nov 19, 2004 09:49 AM
Jason T
1978 - 1996 Big Bronco
Mar 4, 2004 03:22 PM
Nate Stanley
Jul 31, 2003 07:55 AM
jtfwad
Jan 10, 2003 12:23 AM
