Possible hub replacement?
Old Nov 1, 2016 | 06:20 PM
Donny_D's Avatar
Donny_D
Hey all!
Got some road noise going on always noisy while driving straight or turning to the right. If I take a turn at speed on the highway to the left the noise stops. Sounds normal, once I straighten out the noise returns. So my thoughts are clearly drivers side, but not 100% sure where to start my search. Wheel hub is my first thought, is there anything i can do to check if the hub is good since they are sealed?
Thanks in advance
Old Nov 1, 2016 | 08:17 PM
pirschwagon's Avatar
pirschwagon
Originally Posted by Donny_D
Hey all!
Thanks in advance
Lift the vehicle weight off the wheel. Using hands at 12 and 6, check for any movement. There should be none.
Old Nov 1, 2016 | 09:47 PM
Rikster-7700's Avatar
Rikster-7700
Even if there is play at 12 and 6 you may want to look at your balljoints too, they will exhibit the same behavior.....
RV_Tech's Avatar
RV_Tech
x2. Get the weight off the suspected problem child. Check for play and spin it checking for smoothness and listen for sound.
Steve
Old Nov 1, 2016 | 09:54 PM
Donny_D's Avatar
Donny_D
Will check that tomorrow at work thanks. Thought that test was just for ball joints. I'm not herring any knocking at all. Which is why I didn't think it was ball joints. Will update tomorrow though!
ANigrelli132
Jun 24, 2014 10:38 AM
DND58
May 6, 2011 09:58 PM
CAT_man_963
Dec 30, 2006 04:47 PM
wallacemerritt
Jan 10, 2005 05:19 PM
