Help several electrical issues
Old Nov 1, 2016 | 08:40 AM
97puller's Avatar
97puller
I have a few issues with my 05 f150 that I need some advice on how to fix them
-the odometer display flashes on and off, the warmer it is outside the less it stays on
-heater blower doesn't work when the switch is on number one position, works fine on other positions
​​​​​​-power mirrors don't work neither side
Old Nov 4, 2016 | 08:49 PM
steve(ill)'s Avatar
steve(ill)
04-08 Odometer Blackout Fix - Ford F150 Forum - Community of Ford Truck Fans
Old Nov 4, 2016 | 08:59 PM
steve(ill)'s Avatar
steve(ill)
one common problem with blower motor when you have a couple speeds, but missing one or 2 speeds, is the blower resistor......... this is a block that is screwed to the air duct below the glove box and has 4-5 wire harness plugged into it.. Various resistors to drop voltage to motor and vary the speed... you have 1-2 resistors burnt out. Remove the block and examine. Check continuity across terminals to verify it is bad... also check the electric plug for overheating and damage.
Front Heater Blower Motor Resistor For 2004-2011 Ford F-150 #973-444 4P1361 | eBay
Old Nov 12, 2016 | 08:33 PM
97puller's Avatar
97puller
Thanks guys
MDSuperDuty
Escape & Escape Hybrid
Nov 22, 2017 05:52 PM
chadcam84
1997 - 2003 F150
Feb 26, 2014 09:49 PM
cbrguy
1997 - 2003 F150
Jun 12, 2011 09:52 PM
fordgirl07
1997 - 2003 F150
Oct 25, 2010 02:19 PM
sp21
1997 - 2003 F150
Aug 20, 2010 11:00 PM
