Won't shut off!
Old Nov 2, 2016 | 04:25 PM
Frozen_Joker's Avatar
Frozen_Joker
Originally Posted by madpogue
That's the trigger wire for the starter relay coil circuit. See post #10. That's the one that's energized by the ignition switch (by way of the clutch switch, or, in your case, the clutch switch bypass). The one you have to test. Get a voltmeter; it's cheaper than any other part you'll be troubleshooting at this point; troubleshooting without it has already gotten expensive (the starter relay might have been fine) and will get moreso. You need to test for voltage at that ^^^^^ wire while an assistant holds the key in the START position. If no voltage, check at the clutch switch bypass, key in START. Continue following "upstream".
Have you confirmed that your bypass for the clutch switch is still in place?
I was going to grab one when I go out shortly. There was no doubt the parts I already replaced were bad. Hell, the ignition switch was burnt to a crisp on the inside. xD I did check the bypass is still in one piece. Thanks for clarifying that wire. I'll check it out.
IamLee
Jan 16, 2018 07:53 PM
7.3 Fan
Jun 8, 2012 10:05 PM
Blankie
Sep 29, 2007 08:53 PM
'71 f100
Electrical Systems/Wiring
Nov 27, 2004 04:10 PM
muttsby
1997 - 2003 F150
Feb 26, 2004 01:08 PM
