Up fitter switch question
Old Jan 15, 2018 | 11:20 PM
IamLee's Avatar
IamLee
I bought two LED light bars. They are 40 amps each. They each come with a wire harness, relay , and switch. It is meant to hook up directly to the battery. I have other plans for the two 40 amp upfitter switches. So i’m hoping to save them. Any thoughts on utilizing the relay and direct hook up to the battery and one of the 25 amp upfitter switches for each of the light bars?
Old Jan 15, 2018 | 11:46 PM
HRTKD's Avatar
HRTKD
If you have a relay then any of the low power upfitter switches will work. If you wanted both of the light bars on at the same time then one switch that could do also. The upfitter switch is telling the relay to turn on. The actual power for the light comes directly from the battery, not the switch.
Old Jan 16, 2018 | 12:11 AM
azking_Ranch's Avatar
azking_Ranch
Hardwire from battery through fuse and the relay contacts to the lamps , use one of the lower rated switches to power the relay coil.
Old Jan 16, 2018 | 12:21 AM
IamLee's Avatar
IamLee
Thanks Guys. That’s what I was thinking, but wanted to be sure.
Old Jan 16, 2018 | 07:42 PM
IamLee's Avatar
IamLee
Alright, I may have spoken too soon. My question should’ve been, how can I use the single powered 25 amp wire from my upfitter switch to power a relayed , fused, battery powered, 40 amp LED light bar?
Old Jan 16, 2018 | 07:53 PM
HRTKD's Avatar
HRTKD
Power from the upfitter switch will go into one of the prongs on the relay. The schematic for the relay will tell you which prong to use. I think it is fairly standard so a schematic for another relay that is similar to yours should work, but I would always verify that using the OEM schematic or instructions.
ATC Crazy
Apr 26, 2019 02:40 PM
Norris McCarty
Dec 31, 2018 07:05 AM
stroker870
Electrical Systems/Wiring
Apr 10, 2011 07:51 PM
randomhero1172
Oct 19, 2007 08:33 AM
Miz05
Jan 19, 2002 03:03 PM
