Weird Vibaraton
Old Oct 30, 2016 | 10:43 PM
somdford's Avatar
somdford
Weird Vibaraton
I have a 05 250 that i thought was a carrier bearing. I get a vibration between 45-50 and goes away. I have some rim rash on the rear passenger side which is farthest away from the driver. Not certain its the rim, carrier bearing. The part I don't understand it that when there's a load of only about 50 LBS in the bed the vib isn't there....what's causing the vibration not under a load???
Thanks, the truck is it in the picture!
Old Oct 31, 2016 | 12:59 PM
steve(ill)'s Avatar
steve(ill)
I would be looking more at loose sheetmetal. brackets, muffler hanger, etc.. Having a small load in the bed seems to dampen the noise, would not think a bearing / hub/ driveshaft.
Old Oct 31, 2016 | 04:18 PM
EBC-150's Avatar
EBC-150
Bed shake/vibration was a common issue in some of the earlier 11th gen's. Ford starting placing a frame vibration damper on the later models. My '07 has it, a huge cast iron weight on top of the right rear frame rail mounted in rubber dampers.
Old Nov 1, 2016 | 05:38 AM
somdford's Avatar
somdford
Originally Posted by EBC-150
Bed shake/vmibration was a common issue in some of the earlier 11th gen's. Ford starting placing a frame vibration damper on the later models. My '07 has it, a huge cast iron weight on top of the right rear frame rail mounted in rubber dampers.
how do you diagnose that? I'm comes at about 46mph and goes away the about 50mph
thanks
DanielT28
Aug 28, 2014 09:37 PM
CrazyMiracleMan
1983 - 2012 Ranger & B-Series
19
Dec 15, 2011 11:30 PM
dfboothe
Sep 20, 2010 09:28 PM
georgiabuck
Aug 19, 2010 11:13 AM
70T351W
Jun 30, 2005 09:21 PM
