Brake controller
Old Oct 30, 2016 | 07:34 PM
kefrko's Avatar
kefrko
Originally Posted by camocrewcab
I have a tekonsha voyager and it will only light up with trailer plugged in with good wiring. Light is green to tell you wiring is good and orange/red depending on output when braking.
the fact that my blue wire is energized makes me think something is wrong but what you said is interesting. Out of curiosity, does the light illuminate at all if a trailer isn't hooked up but the brakes are depressed?
Old Oct 30, 2016 | 07:54 PM
RV_Tech's Avatar
RV_Tech
Here are the instructions. http://www.tekonsha.com/support/installation/N9030.pdf.
The point about no light with no trailer is important. I was thinking there was a trailer, but obviously that was my mistake. Normally there is a very low voltage that passes down the blue lead to verify there is a trailer.
Steve
Old Oct 30, 2016 | 07:57 PM
camocrewcab's Avatar
camocrewcab
No, it does not light with out trailer plugged in.
Old Oct 30, 2016 | 08:13 PM
kefrko's Avatar
kefrko
Originally Posted by RV_Tech
Here are the instructions. http://www.tekonsha.com/support/installation/N9030.pdf. The point about no light with no trailer is important. I was thinking there was a trailer, but obviously that was my mistake. Normally there is a very low voltage that passes down the blue lead to verify there is a trailer. Steve
I'm using a digital volt meter to test for 12v. Could it be showing the volts but might not have the amps to light a test light?
Old Oct 30, 2016 | 08:29 PM
RV_Tech's Avatar
RV_Tech
To test any brake controller, if you can hook to a trailer, you have to at least have magnet inline to mimic the trailer. I can't recall off-hand, but I did a write-up on testing the built-in controller for the towing site and I think the output was well under 1 amp so that may not be enough.
It is really hard for most folks to test a controller at home as the manufacturers say all testing has to be done in amps, not volts and no test lights please. I use an emulator which mimics the entire trailer braking system when I test, but it is not practical for most folks given the cost and infrequent use.
Is there any way you can test with a trailer? You need some kind of a load and I doubt a test light is enough.
Old Oct 30, 2016 | 08:34 PM
kefrko's Avatar
kefrko
To test any brake controller, if you can hook to a trailer, you have to at least have magnet inline to mimic the trailer. I can't recall off-hand, but I did a write-up on testing the built-in controller for the towing site and I think the output was well under 1 amp so that may not be enough. It is really hard for most folks to test a controller at home as the manufacturers say all testing has to be done in amps, not volts and no test lights please. I use an emulator which mimics the entire trailer braking system when I test, but it is not practical for most folks given the cost and infrequent use. Is there any way you can test with a trailer? You need some kind of a load and I doubt a test light is enough.
that's the rub. The trailer that i need to pick up is about a hour away so I wouldn't want to get there and realize I have an issue. I guess I could try hooking it up to my friends trailer because if it's not working I will need to borrow his truck anyway. I was just hoping to use my truck and avoid an extra trip.
Old Oct 30, 2016 | 08:47 PM
RV_Tech's Avatar
RV_Tech
I should have caught it, but in your opening post when you talked about all the lights working I assumed you had a trailer there and were working backwards when the brakes weren't working correctly. I am sorry for assuming incorrectly as it colored my statements.
Brake controllers almost never fail and that is a fact. The liability a failed controller poses for their manufacturers is so high, this is the single most reliable component in the RV industry. I do not think you have two failed controllers. The odds are very great you are ready to roll. If I were you, I would chance it.
Steve
Old Oct 30, 2016 | 10:39 PM
268Fords's Avatar
268Fords
My tekonsha p2 wouldn't light up unless there was a trailer connected. I just switched to a p3 and says right on the screen that there isn't a trailer connected. The p3 has a trouble shooting program built into it and one section shows the output voltage. It shows the voltage at 1v or so at very little pedal input and rises the more you step on the pedal. I would be willing to bet your brake controller is working properly, just very hard to test without a trailer connected.
Old Oct 31, 2016 | 01:58 AM
RV_Tech's Avatar
RV_Tech
Agree
Steve
Old Oct 31, 2016 | 07:31 AM
kefrko's Avatar
kefrko
Agree Steve
so I think I'm in business. I did the testing again at the controller with the volt meter and still had 12v on the blue. Then I checked with a test light and it wouldn't light. I repeated the test at the 7pin and had the same results. Thanks for talking me thru this. I'm guessing it had the voltage to check for a trailer and to register the volt meter but not enough amperage to light the light. And with the other FTE members saying that they don't get a light without the trailer, I feel pretty good about making the run to pick up the trailer. Thanks again.
Old Oct 31, 2016 | 07:35 AM
RV_Tech's Avatar
RV_Tech
The only thing I would add to this is it is important to note the absence of a light with no trailer is not universal so be sure to read your manual or go online to read it, in the event you do not have one.
Steve
Old Nov 1, 2016 | 07:38 PM
Supercab's Avatar
Supercab
Wink
BINGO!! We have a winner!! I have the Voyager (I'm old school) and it ONLY lights up when a trailer is plugged in-GREEN to tell you all is OK, then amberish to red, depending on how its adjusted......
The Tekonsha Voyager is a good controller, I've had them in 5 trucks now, never any problem.
mwilliams0326
All Things Towing
Feb 14, 2016 03:15 PM
ol.paynt
Jul 16, 2014 08:30 PM
cusneddie
Oct 20, 2012 08:08 PM
Midnite1987
Jun 20, 2012 06:34 PM
MountainHound
All Things Towing
Mar 14, 2003 11:55 PM
