Glow plug question
Old Nov 23, 2016 | 08:31 AM
  #31
Shawn MacAnanny's Avatar
Shawn MacAnanny
Originally Posted by DJHoff
Hi Shawn! You, are where I came across the info on the 6.0 harness. I just ordered off ebay both sides for 19.95 . It seems it will be a great replacement. I notice that all my old oem bullet connects do not fit too tight to top of GPs. I tried to crimp each closed tighter but its limited as to how far they will tighten. I'm thinking that the original GPs on these engines had slightly larger glow plug stems/bullets. So that now they will not fit so tightly together. The new 6.0 harness probably fits more snug to the GPs as they both share the same gp size stems?
Are you that same member who lost his truck when it was parked on side of road and some drunk hit into a couple of vehicles... You were in court last I heard trying to get a settlement? You've not found a replacement yet?
The 6.0l harness clamps on very hard. It's somewhat difficult to remove it once it's on. I found the bullet connectors I had as replacements to my stock harness just didn't work well at all. They were never tight enough to me.
That was someone else. A dump truck decided to not stop at a stop sign and hit me broadside on the highway. I have a 96 psd as my replacement. A good idi turbo was harder to find on short notice.
Old Nov 23, 2016 | 09:04 AM
  #32
DJHoff's Avatar
DJHoff
Chillman88, From above I wasn't able to tell if you had the newer 7.3 glow plug system and are thinking of switching over. I have heard that if the glow plug system seems behaves strange the controller can be gone? Most seem to like the 7.3 system. My 87 6.9 does have the newer system as stock. The drawback most have is with its location so they kick them off to the side.. especially if they've added a turbo which is something I intend to do. (adding turbo) I'm trying to work out all the small issues I have before adding a Turbo over top, hiding from sight and limiting access to the fuel / glow plug system. With the problems you are having I would also yank those injectors and clean them as I stated above. Its an easy task that has worked out great for me more than once.. saves the cost of new ones. If you can have them pop tested that might be a good idea. I didn't bother because anything is better than what I had (leaking injectors) After cleaning them did close nice and tight with an air pressure test. Washers adjust the pop pressure. Those who test them will say they are no good because the pop is off. Not true! The washers on top of spring change the amount of pressure as you've extended the length of the spring with another washer it takes more pressure to open... thus each injector, due to slight differences in spring resistance, has differing number of washers. So purchase a couple of used Injectors for the springs and washers and adjust your old ones with those parts to get the pop corrected. Or if you find the needle will not seat to cylinder opening try a different needle valve out of the spares you've purchased. I'm willing to bet even a 200k mile vehicle has salvageable injectors.
NCFarmLife
Mar 1, 2017 10:24 AM
Shmit90051
Mar 14, 2013 08:46 PM
tygerrrr
May 12, 2011 11:21 AM
West
Oct 8, 2007 10:53 PM
Ace of Spades
Aug 8, 2004 01:29 AM
