Glow plug/ Starting issue
Old Mar 14, 2013 | 05:42 PM
Shmit90051's Avatar
Shmit90051
I have a 1985 ford f250 6.9, just started having problems starting, i have a new relay hooked up to switch in cab light comes on. I replaced 6 glow plugs zd-1a motorcrafts. when i try to start it it just cranks and cranks fast enough to start. use starting fluid fires right up. Is there a way to bypass the glow plug controller??? Ive heard just unpluging the controller?? Also on warm start ups it idles fine then starts chugging and will stall then hard to start after.. if you keep it running (givving it fuel) it smooths out and runs fine. I need to know if im better off bypass the the GP controller or buying a new one (almost $200!!). Also any diagrams will help very much on how to bypass..
Old Mar 14, 2013 | 06:54 PM
tecgod13's Avatar
tecgod13
How old are the return lines?
Did you read the sticky at the top of the forum on the old style glow plugs?
Old Mar 14, 2013 | 07:07 PM
4x4 ext.'s Avatar
4x4 ext.
Either can ruin new glow plugs fairly quick. I'd avoid using it all together.
Old Mar 14, 2013 | 08:44 PM
Shmit90051's Avatar
Shmit90051
read the forum..how do u bypass the gp controller all together so i can just
Run them manual from a switch? Any idea on warm start ups spuddering n stalling?
Old Mar 14, 2013 | 08:46 PM
Shmit90051's Avatar
Shmit90051
Return lines on injectors are updated probably needs changed.. I want to get new ip pump n injectors but don't have cash right now lol
chillman88
31
Nov 23, 2016 09:04 AM
Shawn West
Oct 2, 2013 11:29 AM
ahmincha
19
Mar 17, 2009 08:54 PM
RougeDoc
Mar 11, 2009 12:16 AM
89toyhauler
13
Nov 30, 2008 07:52 AM
