Sponsored by: Real Truck
engine damage?
Old Oct 29, 2016 | 09:26 AM
TruckoffFord's Avatar
TruckoffFord
engine damage?
Was driving on freeway when I heard a noise- thought something hit the truck.
Was just 1/4 mile from getting off the freeway, when I hit my brakes and discovery hardy had any. Pulled over, raised the hood and found my belt was destroyed. Live only about a mile away and thought i could make it (I know, what a dum *** move). Never made it before the temp gauge got close to the red. Pulled over and called a tow truck.
What happened was the water pump gave out (311K).
I am wondering what damage I might have done to the engine (2003 6.0).
Shop said they won't know anything until a new pump is installed.
Can someone tell me what to expect.
Thanks
Old Oct 29, 2016 | 10:58 AM
Just Strokin's Avatar
Just Strokin
If there were minimal water escaping the cooling system when you pulled over the second time, probably no damage. If no water in the cooling system, you can only know once pump is replace and you test cooling system to see if there are any problems.
Old Oct 29, 2016 | 08:04 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Don't buy trouble, get the new pump in and see what happens. If there was water in it, odds are in that time window the oil temps didn't get to the point of really damaging anything. If the plastic standpipe in the oil filter housing is intact and not melted, you'll hopefully be ok.
Old Oct 29, 2016 | 08:59 PM
droldsmorland's Avatar
droldsmorland
Smell the oil. If it smells ok not burnt then your likely ok.
Old Oct 30, 2016 | 09:14 AM
TruckoffFord
Thanks for the replies!
the water will still full
Will know more tomorrow when I get the truck back
Thanks again
Flying Finn
17
May 15, 2011 05:26 PM
strokin'_tatsch
Jul 18, 2007 07:45 AM
460f350
Feb 22, 2006 01:54 PM
mooktank
Jul 22, 2003 06:32 PM
200000+F150
May 18, 2003 12:03 AM
