Water Pump Troubles
Old Feb 17, 2006 | 03:50 PM
460f350's Avatar
460f350
Water Pump Troubles
I replaced the water pump on my 1990 f350 w/460 a month and a half ago because it had gone out and now the new water pump is doin the same thing
is it just a defective water pump?
or could it be something else that is making the waterpumps go out?
when the water pumps went out each time the made a screaching sound that never stopped and coolant sprayed everywhere
Old Feb 17, 2006 | 06:59 PM
Ultramagdan's Avatar
Ultramagdan
Did you purge the system? Sounds like you have something in the fluid that is trashy the bearings. Did you manually try to rotate the first one after you removed it?
Old Feb 17, 2006 | 10:04 PM
Iron Horseman's Avatar
Iron Horseman
Alot of times the reason for the first failure is some corrosion in the system and should be flushed before installing a new one. I'd take the new one back for a replacement and then flush the system and replace the coolant.
Old Feb 18, 2006 | 03:46 PM
Bdox's Avatar
Bdox
Be sure that the belt tension is correct.
Old Feb 22, 2006 | 01:54 PM
460f350's Avatar
460f350
Yea I didnt purge the system good thinkin ill do that second time around
