Review and Plan for Trailer Camera Kit
I finally unpacked the box of stuff labeled Trailer Camera Kit. I took a bunch of photos, checked connectivity, and wrote up some notes. Everything can be found in the document link below. Comments and advice welcomed.
GASCAN - Trailer Camera Kit Review and Plan
And for those of us up north, don't forget the dielectric grease on ALL trailer and camera connections. Keep the evil salt water out!!
your existing camera setup is the same as mine, different seller, but same cables, on your 5 pin connector you'll probably find that pin 1-4 have wires pin 5 is empty. On mine pin 1 is video, yellow wire, pin 2 power-red, pin 3 Audio-black and pin 4 is ground- bare wire.
Thanks. Once it all gets here I will work on the best options since the primary use will be on the slide in camper. I will have to add a jack to the drivers side front of the PU box for the camper plug and I will investigate the best routing and connections to incorporate the camera plug. And I might still just get a Blue Oval camera as was used in the past and put the Blue Oval on the back of the camper and plug it into the existing tailgate connection so it always comes on in reverse. So many questions and no place to experiment. DumDeDumDeDumDeDum. Oh well I have my tonneau, Husky liner for the rear seat, front will be ready to order this week, camper hold downs just need to be ordered, stable loads are here. Only one thing missing at the party
