Another DPF Delete Question....
Old Oct 26, 2016 | 05:36 PM
jawest79's Avatar
jawest79
Hello forum members,
So in the past eight months that I've had my 2012 F250 I have had to take it to the shop to get the EGT sensors replaced and the heat sender unit in the DPF tank replaced. Thankfully under warranty, but as soon as the warranty is gone these things can cost me a pretty penny.
So, I am in the beginning stages of my DPF delete process.
I am pretty confident with tools and basic maintenance, so I can do all the maintenance myself. Here are my questions?
1. Where do you get the best deals for delete kits?
2. Can it be done by one person, or is it something for a specialist?
3. The EGR confuses me, I can easily remove and reinstall a pipe under the truck. But how difficult is it to block the EGR?
Any help that you all can provide would be very much appreciated.
Old Oct 27, 2016 | 05:55 AM
Magnolia Tom's Avatar
Magnolia Tom
Subscribing....I'm looking to delete mine as well. You may get more replies posting in the 6.7 forum
Old Oct 27, 2016 | 03:06 PM
Deuce40s's Avatar
Deuce40s
Subscribing as I'm in the same boat. What I've learned:
1. The best deals come from a few of the major vendors, but you have to call for that good price.
2. Any shade tree mechanic can do it. Use penetrating oil liberally. The exhaust is very heavy/awkward so it helps to have a small jack or another pair of hands.
3. The EGR block off is simply unbolting some pipes and reinstalling their respective block off plates with the EGT sensor. The EGR delete is more involved, I plan to leave mine on and blocked off.
Old Oct 27, 2016 | 05:08 PM
jawest79's Avatar
jawest79
You got any recommended vendors?
Also, I'm looking for an online tutorial for blocking off the EGR but so far I've come up empty or extremely vague. Do you know of any?
Thanks
Old Oct 28, 2016 | 05:14 AM
redford's Avatar
redford
FTE Leadership Emeritus
Moved to 6.7L Power Stroke Diesel engine forum.
Old Oct 28, 2016 | 07:18 AM
PlayersZ28's Avatar
PlayersZ28
Block off method is easier, no cooler to remove. For most of the plates one of the EGT sensors goes into a plate.
For the DPF it depends on what type of exhaust setup you want. Either full replacement or a delete pipe, sometimes call a race pipe.
I'm waiting on a FloPro delete pipe and block off kit.
Old Oct 28, 2016 | 11:15 PM
bobv60's Avatar
bobv60
Anyone have a favorite delete programmer?
Old Oct 29, 2016 | 01:09 AM
94ruck's Avatar
94ruck
sctx4 came with my kit from Rudys and i set up the tow tune, changed my wheel size and performed the delete and very happy with the results
rtazz17
Jul 23, 2019 10:22 AM
brkncly
6.4L Power Stroke Diesel
Aug 2, 2012 08:25 PM
hollywood465
15
Feb 2, 2011 10:36 AM
captain_trucks
Apr 30, 2009 02:25 PM
Fxehogg1
General Diesel Discussion
Feb 2, 2007 09:41 PM
