can't pull a load
Old Nov 9, 2016 | 12:14 PM
  #46
ExPACamper's Avatar
ExPACamper
great news!
Old Nov 9, 2016 | 01:52 PM
  #47
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Originally Posted by RV_Tech
One of the things I am noticing is the Bosch pump runs for about 20 seconds to build pressure when I turn the key. I never heard the OEM pump. From reading on the Internet it sounds normal, but I am not sure why I never heard the OEM pump in the past.
The truck runs and starts fine.
Steve
Glad you're back on the road!
There is a foam cushion between the pump and bracket. Maybe this install is less perfect than the original, or the cushion is damaged, leaving some metal to metal contact to transmit the noise.
The 20 second run at key over is normal. If it starts it gets power full time.
Old Nov 9, 2016 | 02:50 PM
  #48
RV_Tech's Avatar
RV_Tech
Thanks, I thought the run time was normal. I will have to check to see the position of the cushion.
Steve
Vsanzbajo
Feb 11, 2013 10:38 PM
sufferingant
May 13, 2010 11:29 PM
fergysamsoil
Sep 6, 2006 11:21 AM
Fire Rooster
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jun 3, 2006 02:15 PM
Gibber 1
Jan 19, 2006 08:10 AM
