Sponsored by: Real Truck
Cruise control again
Old Oct 25, 2016 | 06:35 AM
Superk401's Avatar
Superk401
2003 f-250 superduty 5.4 6 speed. Cruise control worked intermittently for a while then stopped. When doing diagnostics all buttons flash and at the end I get one flash. The chart starts at two flashes. Any one have any idea what one flash means?
Old Oct 26, 2016 | 12:02 PM
Mike1's Avatar
Mike1
The way I'm reading it and you're describing it, it sounds like your switch is not defective. If you did each test and it passed, then there is one flash after SET/ACCEL it's good.
*cruise control self test*
Enter self-test diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel
will flash once to indicate that speed control module entered the diagnostic mode. Five additional flashes at this point indicate a defective speed control servo. Release the OFF switch.
Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
If the ON switch is not depressed within five seconds after entering the diagnostics mode, the module times out and the procedure must be started over.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
NOTE: There will be a slight delay when the last button is pressed and the lamp flashes.
A lamp flash with the last button (SET/ACCEL) indicates that the static test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
3 flashes - deactivator switch is open or circuit defective.
4 flashes - vehicle speed signal is out of range or circuit is defective
Immediately (.25 second delay) after the static test, the speed control servo does a dynamic test by automatically actuating the throttle lever from 8 mm (0.315 in) to 12 mm (0.472 in) of travel from the idle position. During the dynamic throttle pull, observe throttle movement to witness any binding or sticking of the speed control cable and correct connection of speed control cable to throttle lever. Make sure the throttle returns to the idle position.
bust7015
Feb 24, 2016 10:53 AM
Tugly
38
Nov 25, 2014 07:02 AM
handyandy123
Mar 15, 2013 06:30 PM
XbigXredX
Jun 4, 2012 10:42 PM
Estam
Electrical Systems/Wiring
16
May 21, 2012 06:53 PM
