Cruise Control not working
Old Mar 15, 2013 | 05:37 PM
handyandy123's Avatar
handyandy123
2003 X limited 2wd 6.0L
Hi everyone.... my cruise control was working intermittingly. has anyone experienced this? Could it be the buttons on the steering wheel itself? there is a cluster that I see. Does it pop off to expose the connectors/switches? Can these go bad? Can I buy new switches for the steering wheel?
Thanks again!
Old Mar 15, 2013 | 06:24 PM
ComputerCowboy's Avatar
ComputerCowboy
Enter self-test diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel will flash once to indicate that speed control module entered the diagnostic mode. Five additional flashes at this point indicate a defective speed control servo.
Release the OFF switch.
Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL. If the ON switch is not depressed within five seconds after entering the diagnostics mode, the module times out and the procedure must be started over.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch. NOTE: There will be a slight delay when the last button is pressed and the lamp flashes.
A lamp flash with the last button (SET/ACCEL) indicates that the static test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective. If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
3 flashes - deactivator switch is open or circuit defective.
4 flashes - vehicle speed signal is out of range or circuit is defective
Immediately (.25 second delay) after the static test, the speed control servo does a dynamic test by automatically actuating the throttle lever from 8 mm (0.315 in) to 12 mm (0.472 in) of travel from the idle position. During the dynamic throttle pull, observe throttle movement to witness any binding or sticking of the speed control cable and correct connection of speed control cable to throttle lever. Make sure the throttle returns to the idle position.
Old Mar 15, 2013 | 06:30 PM
handyandy123
Thanks Cowboy!
Superk401
Oct 26, 2016 12:02 PM
bust7015
Feb 24, 2016 10:53 AM
Tugly
38
Nov 25, 2014 07:02 AM
Estam
Electrical Systems/Wiring
16
May 21, 2012 06:53 PM
Thudpucker
1997 - 2003 F150
Aug 30, 2009 10:29 AM
